H Belt Pully Leak
Gary Puckett
09-30-2007 16:06:11
I replaced the seal for the belt pully shaft on my H and it does not leak. However, it does leak around the two lower bolts(three total in a triangle pattern)that fastens the bearing flange to the housing. Should there be a sealer around those bolts or is there something else I should have done? They did not have washers. Thanks
neblinc
10-03-2007 07:35:34
 Re: H Belt Pully Leak in reply to Gary Puckett, 09-30-2007 16:06:11
Wow! Excellent post Wayne!
I will be printing this, as my 43H leaks really bad.
Randy
neblinc
10-03-2007 07:33:51
Kenneth
You can go to the CaseIH website and look up parts there.
Also ask any questions you have right here, lots of knowledgeable people on these boards.
Randy
CaseIH
Wayne in MN
09-30-2007 18:38:41
My 2 sons & I recently re-did 2 gearcases for the belt pulleys on their "H"s".
Remove the capscrews under the pulley mounting flange and the shaft, spacers, & bevel gear will all slide out with a bit of assistance.
Remove the cap screw on the end of the shaft and all the parts can be pulled off.
I was able to obtain replacement bearings at no cost by going to an electric motor rebuilding shop. If my memory is correct you need a 6210 & 6208 bearing for the drive shaft. Remove any shields so the bearing will now lube itself from the transmission oil. Thoroughly clean all old grease residue before installing the used bearing. Factory bearings run $50 or so for the big one so it can be an expensive affair to replace them. NAPA wanted $45 for the 6210 size.
I have a Case/IH dealer in town (Fergus Falls, MN) so obtained the new seal, felt dust washer, and mounting gasket from them at a very reasonable cost.
Carefully clean the metal spacers and put a VERY light coating of silicone on them just before assembly. Don't mix up the cap screws from the drive gear cover with the shaft cover; they are longer (don't ask how I found out) and will not compress the spacers under the pulley flange.
On the drive gear shaft, just remove the 3 cap screws and pull the unit out. Remove 2 fine threaded cap screws & take the bevel gear & bearing off. It is a 6206 size. Watch out for the shift lever plunger & spring as they will jump out if the lever is moved too far. And this will happen as you clean the gear-case. If you need to replace the steel plug in the back of the gear-case, IH doesn't have it any more. Go to an automotive parts rebuilder and get a 1 3/16" soft plug; it can be deeper (longer) than original. Put the spring & plunger back in place, set the large drive gear on the shift lever. Clean & lightly silicone the spacers and reassemble. The 2 long bolts had copper washers but a dab of silicone will work. Be sure to put them in place in the gearcase BEFORE you slip it into place on the tractor. They won't go in later unless you remove the gas tank or pull the gear-case back out. (I know, experience is a great teacher)
It goes without saying to carefully scrape all old gasket residue off before reassembly. Careful use of a 10" or 12" mill file will do wonders. Use it as a draw file ( sideways motion, not forward & back) to locate any high spots on the metal casting also.
I now have 2 belt pulley gear-cases that work just like new at a very minimal cost. Sorry for the long post, I was a Vocational Engines instructor in my past life and just can't quit teaching!!
Good luck.
Kenneth Ondracek
10-03-2007 07:15:11
 Re: H Belt Pully Leak in reply to Wayne in MN, 09-30-2007 18:38:41
I too have a horrible leak from my belt pulley - where can I obtain a drawing showing the actual bearing needed and I am interested in correspondence with anyone who has and works on H's as I own one and need some questions answered. Thanks a lot.
Janicholson
09-30-2007 17:10:19
If they are leaking under the hex of the bolt, I would put a copper washer under each. Good ardware stores will look in plumbing stuff until found, or make some out of sheet copper. (flattening and drilling old (real copper)copper pennies would work) JimN
