B250 British Diesel Injector pump
Richard Lee
10-04-2007 05:45:17
I ordered the injector pump manual for my tractor and its showing a different pump than the one that is on the tractor, can anyone tell me was there different pumps used the same years it sure looks like the original pump. And where can I get parts for this pump. Thanks
DougM
10-04-2007 16:42:03
 Re: B250 British Diesel Injector pump in reply to Richard Lee, 10-04-2007 05:45:17
third party image
Richard, does your pump look like this?
Richard Lee
10-05-2007 05:52:22
 Re: B250 British Diesel Injector pump in reply to DougM, 10-04-2007 16:42:03
It looks exactly like the first picture. thanks Richard Lee 17806624776 17809156174
DougM
10-05-2007 09:32:12
 Re: B250 British Diesel Injector pump in reply to Richard Lee, 10-05-2007 05:52:22
Richard, that pump is a CAV model BPE, it was used on the early built 144 engines in the 250 & 275. some where around 1959 they changed to the one in the second picture which is still a CAV pump but is a DPA model rotary style pump. Not sure where the engine serial # break for the change on the 144A engines happened but on the 144C engines it was # 1950.The rotary pump will not bolt onto the earlier engines as they changed the front geartrain cover & drive gear for the later pumps.
I think you would need to find a good fuel injection shop to locate parts for the earlier pump,When I had mine checked on the test stand at a fuel injection shop they stated some parts were getting harder to come by for these pumps, luckily the only thing mine needed was the transfer pump which they had in stock.
DougM
10-04-2007 16:44:32
third party image
Or does it look like this
