mw live hydraulic pump for m farmall
dav_o
10-04-2007 10:47:16
i guess the main question i have is, are the front covers on a m and md different? because the pump i have was on a md. and the mounting holes are not even close to lining up. the ppump is a 204px. i would like to swap the front mounting plate on the front of the pump so i can put this on my m. or any other thoughts? email me yamascooter@centurytel.net
dav_o
10-05-2007 10:39:52
 Re: mw live hydraulic pump for m farmall in reply to dav_o, 10-04-2007 10:47:16
well my next question is, what direction does the motor turn, as if you were sitting on the seat? on a gas m. the pump has an arrow showing direction. if sitting on the seat it is suppose to turn clockwise. the m d gear is different, i put the gas one on the pump with no problem. any more thoughts?? thanks for all the replies
chuck46
10-05-2007 14:40:50
 Re: mw live hydraulic pump for m farmall in reply to dav_o, 10-05-2007 10:39:52
Hi again Dav-o, If your pump is to turn CW from the seat I am afraid it is the wrong pump. On a gas M the gear that drives the ignition turns CCW. If your pump only works in one direction and it came off an MD it will not work on a M. Good luck, Chuck
Dairy farmer in WI
10-04-2007 19:04:07
sorry for teh stupid question but...i have an M with a live hyd pump opn it. now is the M&W pupmp the one with the hoses coming out the bottom or top. i seen both before but don't pay much attention.
DF in WI
chuck46
10-04-2007 23:24:18
 Re: mw live hydraulic pump for m farmall in reply to Dairy farmer in WI, 10-04-2007 19:04:07
Hi DF, M&W pumps have the hoses at the top, both openings have 3/4 inch pipe threads. The IH pumps have O-ringed openings at the bottom and reguire a port block, Chuck
chuck46
10-04-2007 15:58:55
Hi Dav-o, I have 2 M&W pumps 205px, it is my understanding that they will work either direction. If you find the right mounting plate the pump should be OK. On a gas you pressure port will be the farther one from the engine. Good luck, Chuck
georgeky
10-04-2007 11:20:06
The pumps turn in opposite directions. One from the MD will not work on an M.
Janicholson
10-04-2007 11:18:44
Unfortunately the Hydraulic pumps (and drive shafts turn opposite directions CCw on a MD CW on an M. Thus the whole thing becomes rather moot. JimN
georgeky
10-04-2007 11:21:48
 Re: mw live hydraulic pump for m farmall in reply to Janicholson, 10-04-2007 11:18:44
Sorry Jim, when I started typing your reply wasn't there.
