Farmall A top speed 15
Leroy Abernathy
10-05-2007 16:43:51
Our Farmall A with the rebuilt 123ci engine now has a top speed of 15mph with the stock transmission. Can anyone tell me how many rpm's it's prolly running at right now, and how much faster it could go safely if i open up the governor a bit?
Len Rahilly
10-10-2007 14:18:12
 Re: Farmall A top speed 15 in reply to Leroy Abernathy, 10-05-2007 16:43:51
Another comment: This tractor is narrow and I expect that the CG is high. It wouldn't take a lot to tip it over in a fast turn, I'd bet.
There always used to be a warning decal about high-speed turns, and about locking the brakes together when traveling at high speeds. Pls. be careful!
Len Rahilly
10-10-2007 14:16:14
IHC gives 9-5/8 mph (9.625) at 1400 rpm in 4th gear. Fifteen mph is 1.558 times 9.625.
1400 x 1.558 = 2182 rpm.
Can the engine take it? I don't have any idea, but I expect manufacturers were really cautious when these tractors were made. After all, the previous generation tractors topped out between 1000 and 1250 rpm, depending on the model, and they had splash lubrication. I'm excepting F-12/F-14 from the "previous generation"--they had full-pressure lubrication, and it is at least interesting that the F-14 was notched up to 1650 from 1400 full-load rpm, apparently with complete safety; the H is also 1650, so it looks as if the lower speeds are conservative.
ShaggyM
10-05-2007 21:54:17
I have a super A that will run 22mph (Police radar checked)and that is at 2000rpm with 11.2x24's.The front end is tight so it doesn't shimmy. I don't run it that way for long though. I have it turned down now so it running about 1700rpm but I am not sure of the speed. I did it to stir things up on the Tractor ride I go on and it worked!!
Shaggy
Red Dave
10-05-2007 17:07:42
That is about 50% faster than stock, depending on what tires you have on it.
More? I advise against it.
little john
10-05-2007 16:49:38
Why do you want to go fast with a Farmall A? How fast do you want to go?
Hugh MacKay
10-05-2007 18:25:57
 Re: Farmall A top speed 15 in reply to little john, 10-05-2007 16:49:38
John: Another guy without enough money to buy an ATV. We best order him a tombstone.
flashback
10-05-2007 17:03:11
sounds dangerous to me. I even am leery when My M hits 18.
