H valve roto caps
akb
10-06-2007 21:07:19
All the spring caps on my head look the same
how do you tell the difference between a roto and a non roto.
I thought the H had them ?
Getting close to firing her up.
Thanks for any info.
Janicholson
10-07-2007 10:42:30
 Re: H valve roto caps in reply to akb, 10-06-2007 21:07:19
Rotator retainers have several components to them. and are crimped shut to retain the parts. When the rocker pushes down the retainer turns the valve stem just a bit. This action evens the wear on the valve face/seat making the head last longer. Many times only the exhaust valve has rotators on them. The difference between the rotator retainer, and non rotator is that the non rotator retainers are basically one piece from the spring perch, to the wedge clips on the stem. JimN
