3514 Engine water Pump
Travis Shuman
10-11-2007 15:18:36
I have a IH Industrial 3514 & lost the water pump. Does anyone know what engine was used in this tractor? I was hoping to go right to the engine mfg to get the water pump. If not, does anyone know where I can go to get a new pump?
M/N 3514, S/N 783W, 4 cylinder gas engine. Has a 580 loader, was set up as a back hoe but no longer has the hoe attachment.
Thanks for any info you can provide.
Trav
Kevin Meier
10-11-2007 16:30:22
 Re: 3514 Engine water Pump in reply to Travis Shuman, 10-11-2007 15:18:36
Just a guess but I think that a D239 german diesel engine. The water pump if I am right has a 1" bearing on the hub side with either a cone shape hub or a flat pancake looking hub. I have either one on hand if you find out this info is correct. Like I said I am not positive on the engine.
Kevin
