Oil-bath Air Filter on H
Minnesotan H
10-22-2007 18:44:13
I own a 1943 Farmall H. I just read recently to be sure to have the proper weight oil in the oil-bath air filter. What is the right weight to use? What do you guys load yours with?
Andy Motteberg
10-22-2007 20:41:07
 Re: Oil-bath Air Filter on H in reply to Minnesotan H, 10-22-2007 18:44:13
Use the same oil in the air cleaner as you use in the engine.
Mike CA
10-22-2007 19:27:29
I've always been told to use the same as you use for your engine. In the case of my '44 H, it was recommended to use 15w 40, which is rated for diesel, because it has zinc in it which these old engines need.
Scott Rukke
10-22-2007 19:06:35
Use the same oil as your engine. Usually calls for 30w.
