560 diesel fuel bleeding
Tom/Idaho
10-30-2007 18:25:24
Acquired a 560D today that has sat for a number of years. Have ordered manuals from this site but was wondering what the correct procedure is for bleeding the fuel system? Any help is greatly appreciated. Tom/Idaho
Hugh MacKay
10-30-2007 20:29:56
 Re: 560 diesel fuel bleeding in reply to Tom/Idaho, 10-30-2007 18:25:24
Tom: Should be bleeders on each fuel filter. Once you get both full it should be just a matter of loosening couple of injector lines at the injectors and start cranking. They will usually fire up and as they do retighten the injector lines.
Bear in mind also 282 diesels can be cranky. That being the case, find a tow vehicle that will pull 560 in 4th turning the engine at 1200 to 1500 rpm, still with couple injectors open. If it doesn't start in 1/4 mile, must be something more serious wrong.
