Fuel pump replacement on Dsl IH 364
brmtdg
11-06-2007 12:31:15
I need to replace a leaking mech. fuel pump( not the injection pump) on a IH 364(BD-154 DSL engine). My question is,after replacing the fuel pump does the air that enters the fuel lines during replacement need to be purged prior to cranking? If so what is the correct procedure? Or can I just replace pump, clean out sediment bowl then reassemble check for leaks and fire it up?
I have limited experience on DSL fuel systems so any opinions would be appreciated.I grew up around gas.
Thanks in advance
BRMTDG
