H water pump seal
Flameffects
11-07-2007 20:55:37
Can I get packing at the hardware store or do in need to purchase it from IH. Thanks, Steve
Kevin Meier
11-08-2007 13:54:41
 Re: H water pump seal in reply to Flameffects, 11-07-2007 20:55:37
Make sure you just don"t replace the packing. The impeller has to have a good mating surface also to seal between the center tube and the water cavity.
Mike L
11-08-2007 01:17:57
I used plumers packing. It looks like the same stuff that case has. I got it at a True Value Hardware store.
Flameffects
11-08-2007 05:35:05
 Re: H water pump seal in reply to Mike L, 11-08-2007 01:17:57
Thanks,
I thought this might be the fix.
