300 Starter
Scott300IA
11-08-2007 06:47:54
Will the starter off a Farmall 450 fit a Farmall 300? Both tractors are rowcrop. Thanks for your replies.
Scott300IA
11-09-2007 17:19:07
 Re: 300 Starter in reply to Scott300IA, 11-08-2007 06:47:54
Works like a dream, My 300 is converted to 12 volt. She cranks smooth & quite!
Thanks
D Slater
11-08-2007 16:03:23
Yes, the only problem you may have is that part of the 450 gasoline were 12 volt starter. If you still have a 6 volt 300 it may not crank a 12 volt starter to good. If you are using 12 V on the 300 or both starters are 6 V, bolt it on and go. The original 12 volt 450 starters used a extra terminal on the selonoid to send current past the resistor to coil, but that won't effect you putting it on a 300.
Scott300IA
11-09-2007 07:09:47
 Re: 300 Starter in reply to D Slater, 11-08-2007 16:03:23
Thanks D Slater, I will get it on tonight!
Andy Motteberg
11-08-2007 09:41:47
No, they are different.
