OT cummins help
pieceofjunk
11-09-2007 05:59:05
I have a 93 Dodge 250 with a 12 valve cummins. I replaced an injector and now it will not start. I have tried to bleed it out numerous times, but it seems like it isnt getting much if any fuel through the injection lines. If I unhook all the lines from the injectors and crank it over I only see maybe a drop of fuel come out every once in a while. Do I still have air somewhere? What things should I check for?
brandonf
11-09-2007 19:24:32
 Re: OT cummins help in reply to Brownie450, 11-09-2007 05:59:05
93= rotary ve pump use the primer lever on transfer pump on block pump her up good and then fire the truck, or even keep it running on ether until fuel catches up, be sure to disconnect grid heater if you use ether
Brandon
Dblair
11-09-2007 16:39:45
 Re: OT cummins help in reply to pieceofjunk, 11-09-2007 05:59:05
there is a manual pump that you are suppose to use just behind the p7100 pump. disconnect or loosen your injector lines and pump untill fuel comes out the lines tighten them down and it will start . you must be a real rookie on diesel engines the b5.9 is the best small engine on the market
mtdan
11-09-2007 06:27:32
I would check the lift pump..right above the starter. make sure it is working.
