B-275 diesel ??
kip in ny
11-09-2007 14:43:52
I just bought a b-275 diesel I dont know anything about this model other then its from europe are they commen are thair alot of these in the U.S kip in ny
Pat-CT
11-09-2007 19:08:16
 Re: B-275 diesel ?? in reply to kip in ny, 11-09-2007 14:43:52
truly a great tractor we ahve one at work live pto live hydro ours has they have a weird stater in my opinion where theres a lever that has to be pulled insted of a button but it has dick breaks and it can easly handle a 3 bottom plow they rev to what seems to me a really loud high rpm i never bring the one at work much more then idle even wheen plowing mayby 1/2 throttle at most verry easy starting diesils to execpt ours because the flywheel is like missing some teeth but if you heat the glowplugs for about 40 seconds they will start in about 20 degree weather(again mayby just our tractor) without a block heater or ither
Athol Carr
11-09-2007 18:36:39
The B-275 was British built, Replaced (effectively) the B-250 with a bit more power, the latter had 5 speed box with one reverse, the 275 had two range 4 speed and one reverse box and with the option of independent (continuous) power take off. Replaced later by the B-414. The B-250 was diesel only whereas the B-275 had choice of diesel or gasoline engine.
jakee
11-09-2007 15:10:53
a bunch of them in canada,the glow plugs are like the old christmass lights that if one went out they all went out.
