Farmall M Steering Shaft
Zach Bouchard
11-10-2007 14:52:02
I want to remove my steering shaft so i can take the radiator out. What is the easiest way to remove it?
John M
11-11-2007 05:04:59
 Re: Farmall M Steering Shaft in reply to Zach Bouchard, 11-10-2007 14:52:02
Sorta, remove the cap at the bolster, remove the bolt in the u-joint, then remove the big fat washer in between the slot where the bolt goes through the joint. Never seen one without a washer in there.
poogie
11-10-2007 15:23:11
There is only one way! Remove the screw-on bearing cap on the extreme front of the housing and then remove the universal joint from the other end of shaft. Really quite easy!
Nebraska Cowman
11-10-2007 15:21:40
Take the clamp bolt out of the rear of the universal joint. Take the cap off the front of the steering box. (unscrews with a big pipe wrench) Turn the shaft a little and it will start forward. Then as the universal comes off you can get the woodruff key out of the slot so the shaft can pass through the bearing.
poogie
11-10-2007 15:25:35
 Re: Farmall M Steering Shaft in reply to Nebraska Cowman, 11-10-2007 15:21:40
Sorry Cowman! Looks like we think alike.
