Super C hydraulic pump
wstewart7
11-13-2007 06:56:37
Hydraulic pump on Super C is leaking into crankcase. I assume it is a seal for the main gear. Are there rebuild kits available and where do I find one?
gene bender
11-14-2007 04:46:05
 Re: Super C hydraulic pump in reply to wstewart7, 11-13-2007 06:56:37
You dont need a kit just take off the pump and replace the seal some used an o-ring some used a seal and you wont know what yours is till its apart as never jnow when someone mite have changed from original. If the staft is worn where the seal fits you will need a speedy sleeve or a new seal just wont last. So take your pump off and then you can get the correct seal.
SteveNH
11-13-2007 10:49:18
I am having the same problem on a SA. My kit should be in today. I will let you know how I make out.
Janicholson
11-13-2007 09:38:09
The info below is good, there is also a possible oil pump with a "O"ring seal. It is good to go with a new "O"ring if the shaft is not grooved. If the shaft has a groove that can be felt with a fingernail, the speedy sleeve is needed, and the housing must be bored to allow the sleeve to be put in, and the sleeve must be put on after the pump is assembled dut to the sleeve not going through the bearings. JimN
Ron-Mo
11-13-2007 13:17:39
 Re: Super C hydraulic pump in reply to Janicholson, 11-13-2007 09:38:09
janicholson is correct, and mine had the one with the o ring. I had a very hard time trying to come up with that o-ring. They seem to be an odd ball size, and I finally found one at another dealer, but I will bet I spent $30 in fuel looking until I finally found the right dealer who knew what he was talking about. The first one actually tried to sell me a new pump for over $600. I was wasting his time looking for an o-ring for a 60 year old tractor. I try to avoid that dealer now, but it is difficult since the next closer one is a couple hours away.
El Toro
11-13-2007 07:34:53
third party image
Here's a parts breakdown on your pump. Item No4 is the seal. You need to check that shaft on Item
No.11 for a worn groove usually cause by the old seal becoming hard from age. They have a speedi-sleeve kit for covering the worn surface and I think the seal comes with the kit. Hal
Andrew Z
11-13-2007 06:59:24
Yes there is an oil seal behind the pump drive gear. avaible at a case IH dealer.
Andrew
