Generator vs alternator
Scott Rukke
11-14-2007 21:04:19
I am curious why it is so common to go for the alternator when converting to 12-volt when they make 12-volt generators which would keep more of the original look and possibly fit better.
steve_966_756
11-16-2007 07:33:40
 Re: Generator vs alternator in reply to Scott Rukke, 11-14-2007 21:04:19
from key switch ,wire in a 194 lamp&socket
other wire from lamp to #1 wire on alt.
#2 wire to bat. terminal on alt.
when key is turned on lamp should light
when tractor is started the lamp will go out (my have to rev up engine some)
this is commonly know as an idiot light to some.
or the make a single wire alt. just put the bat.
wire on bat. terminal
steve
Nat 2
11-15-2007 06:43:36
 Re: Generator vs alternator in reply to Nat 2, 11-14-2007 21:04:19
Alternators are more reliable and cheaper. You can get a generic reman alternator from an auto parts store for $35 plus like $5 for a core charge. Where are you going to get a 12V generator for that? The regulators by themselves are at least $42.
Bus Driver
11-15-2007 04:26:42
Once an alternator is "excited" and starts charging, it will charge at lower speeds than will a generator. Most generators do not charge when the engine is idling.
Hugh MacKay
11-15-2007 06:02:45
 Re: Generator vs alternator in reply to Bus Driver, 11-15-2007 04:26:42
Bus Driver: That is a good point, I well remember all those years going to idle with generators, you look down and gauge is on discharge.
Often times at night with a light or two added over and above factory specs, and it will go to discharge even at full throttle. There is a reason why all those old tractors had place to carry the hand crank. It was part of the evolution. I don't even carry the hand crank on my tractors anymore. As I told a chap just yesterday, I thought you had to pay $100,000. for an unreliable tractor. At least that is the take I got couple years back. One of those 350 hp Deere's spent 48 hours parked with 48' cultivator spread.
John M
11-15-2007 03:55:08
Cant get 6 volt bateries around here without paying out the rear for them. As for originality, I have changed over as couple of mine to 12 volt gennys, and a couple to alterantors.
don g
11-15-2007 18:32:41
 Re: Generator vs alternator in reply to John M, 11-15-2007 03:55:08
there is a place in our town that actually makes car and tractor batteries.I checked and a 6 volt is around 50 dollars.They are excellent batteries by the way i buy them for my harley and they out crank and out last batteries twice the price.
Hugh MacKay
11-15-2007 02:40:15
Scott: A lot of folks treat this question as singular in nature, when in fact there are two distinct issues. First being alternator versus generator and the second being 6 volt versus 12 volt. Give me either 6 volt or 12 volt, one will be as successful as the other on pre 1958 Farmalls. Then I find the deepest pit and bury all generators, and bury the regulators 10' deeper.
I have three alternator tractors, a 6 volt Super A and 12 volt 130 and 140, and the SA and 130 have 15 years on them now with alternator, starting in Canadian winters. Not only was my SA the cheapest change over, it has been the most trouble free. bear in mind my tractors have been pretty much work tractors with much improve lighting for night operation. This added and brighter lights is where the generator falls down, just doesn't turn out enough amps to maintain the system.
Back in 1992 I decided to change my 130 to 12 volt as I had a metering attachment on vegetable seeding equipment with a 12 volt motor. I decided I'd keep the generator as a spare for the SA that I would keep 100% original. Within two weeks both generators went kaput. I landed at an auto electric shop, told him I have a new 6 volt battery and this has to be quick as I need this tractor fast. He replied, "Quick with that old generator will be two weeks as I don't have the parts, quick with a 6 volt alternator will be 5 minutes, as all I have to do is change the internal regulator in a Delco, same price as if it were 12 volt. About 45 min fabricating mounting and I had an operating tractor.
As I said that was 1992, basically these tractors have been trouble free electrically ever since. Those old generators cause far more problems than we ever believe. For me gone is that bananna box full of old regulators, caps, points, coils, etc., etc. I go once per year to CaseIH to pick up a supply of oil filters, points, condencers, rotors, caps, etc. Often times this happens when I'm out anyhow, thus I check my inventory from memory. Yesterday, I needed a sediment bowl screen and gasket, decided to go through my inventory. I have 7 sets of points-condencers, 5 rotors, 2 distributor caps, 5 screens and gaskets for bowl, numerous fuses, 6 oil filters, and a host of other items. My point being, electrical is the most predominant surplus item, and that clearly goes back to the generator days and buying these items tooooo often.
Cost is the single biggest factor in favour of the alternator, one can buy a new alternator off the shelf for $45., used at an auto recyclers for $15. and you could very easily sink a $150. rebuilding that old generator, and I'm betting it wouldn't be as reliable as the $15. used alternator.
MapleSprings
11-15-2007 04:03:04
 Re: Generator vs alternator in reply to Hugh MacKay, 11-15-2007 02:40:15
When changing from 6 volt generator to 6 volt alternator, what-- if anything -- needs to be changed at the same time? (I think I may finally be done fooling around with my old JD M electrical system, with the old cut out regulator.)
Thanks.
Mark
Hugh MacKay
11-16-2007 07:10:49
 Re: Mark, attent in reply to MapleSprings, 11-15-2007 04:03:04
Mark: Make note of my findings this morning in my post to JMOR.
MapleSprings
11-16-2007 09:54:48
 Re: Mark, attent in reply to Hugh MacKay, 11-16-2007 07:10:49
THANKS Hugh.
Replies and responses and clarifications duly noted.
Now, if I can get the new greenhouse moved and set up before it gets truly, permanently blasted cold, then I can turn my attention to trying to get the JD M's electrical to actually be depndable!
Thanks again.
Mark
Hugh MacKay
11-15-2007 05:42:23
 Re: Generator vs alternator in reply to MapleSprings, 11-15-2007 04:03:04
Mark: Basically it's build a mount for the alternator, change to negative ground, and I'm guessing your JD M is positive ground currently, same as my SA was. In making that change you must change battery cables, reverse the wires on your amp gauge and coil.
The type of alternator I used was the one with small plug on the side. I purchased a pigtail plugin for that, hooked one of those wires to main alternator terminal. The other initially I used just to scratch on housing of alternator to excite the alternator. Eventlually I ran that wire back to dash, installed a push button switch, hooked wire to one side and grounded other side. After I start the tractor I just give that button a push to excite the alternator. The push button is very important, as you cant afford to forget and leave that on. It will back feed on battery when tractor is not running. All it needs is a quick push on button to excite the alternator. I find this works well, one tends to watch the amp gauge as he pushes the button. I have this on all my tractors, it's simple, it's trouble free, initially my tractors go to heavy charge then drop back quite quickly. It's been 15 years, I'll have to go to tractor and get back to you on which of those wires go to main alternator terminal and which to button.
The biggest single advantage I've found, battery is always fully charged, better for the starter and all other components. I have O gauge battery cables on the SA and I got 13 years out of that new 6 volt battery that was in the tractor when I made the change. Once per year I take the cables off and clean all the terminals. I had never come close to that kind of battery life ever, I always thought 6-8 years was damn good.
I once got 8 years out of a set of 12 volt batteries in a 404 Deere. I thought that was good considering the Deere probably started 300 days of the year, Canadian winters included. I've always done annual cleaning of all my tractors battery cables, and if a cable is looking bad, I'll heave it and go with new. If I loose a battery before it's 5 years old, I consider I over looked something, or made a mistake.
Hugh MacKay
11-15-2007 12:11:16
 Re: terminal with pigtail in reply to Hugh MacKay, 11-15-2007 05:42:23
Mark: Checked my SA, on that plug in side two wire terminal those are numbered 1 and 2 on all my Delco alternators. Terminal 1 wire goes to my push button at dash. Terminal 2 wire couples on main alternator terminal with wire from battery.
JMOR
11-15-2007 13:53:14
 Re: terminal with pigtail in reply to Hugh MacKay, 11-15-2007 12:11:16
Hugh, you said that you use a push button to momentarily ground terminal#1 to excite the field at start up. That sounds very strange to me as that would be grounding the diode trio's output which supplies voltage/current to the field.
I know you said you have been successful for 15 years so I can't help but wonder if the button isn't wired to send battery voltage to terminal #1 upon start up??
I'm sure you know, but had to ask for a conformation.
Thank you.
Hugh MacKay
11-15-2007 14:52:38
 Re: terminal with pigtail in reply to JMOR, 11-15-2007 13:53:14
JMOR: To be honest with you I don't remember exactly how that is hooked behind the dash. It's 15 years since I did my SA and 130 and I suddenly realize it's 4 years since I did the 140. I know I had to take the 130 apart when I did the 140. Glad you brought this up, as I think it must be as you suggest, sending battery voltage to terminal one.
I did the first ones on the advice of the guy that sold me the 6 volt alternator. What I'm seeing this afternoon, all 3 tractors is battery hooked to main alternator terminal. Terminal 2 is hooked into the main alternator terminal and terminal 1 is going to my push buttom switch. What I can't see without removing the battery and can't remember is where is the other side of that push button switch hooked. I remember once comparing this with Bob M's diagrams and it differs little. Can't remember for certain, however I think my push button basically replaces his small lamp. If we can't resolve this I'll remove SA battery in the morning, start following a few wires. I really like my 6 volt alternator, it even has an edge on my 12 volt systems.
JMOR
11-15-2007 19:13:56
 Re: terminal with pigtail in reply to Hugh MacKay, 11-15-2007 14:52:38
It most likely is picking up battery instead of ground. I wasn't trying to be a SA, but rather, more than anything wanting to be sure there wasn't something here that I was missing, and if not to try and help other readers not go down a bad path. OK?
JMOR
Hugh MacKay
11-16-2007 03:02:57
 Re: terminal with pigtail in reply to JMOR, 11-15-2007 19:13:56
JMOR: Your proof that old geezers like me shouldn't post from memory of something they did many years ago. I just came back from my shop and an enjoyable first cup of coffee of the day. While there, I sat on my trusty shop seat, (5 gallon oil pail) between SA and 130 trying to remember what I did almost 15 years ago. Even more so, I was trying to figure out how much I'd have to take apart to trace those wires that don't show much color coding any more.
Then it hit me, pull the plug from number 1 and 2 terminal, put a test light in number 1, the one going to the push button at the dash. I pushed the button, and sure enough, the test light came on. So, yes you are right, my push button is giving a charge from battery to number 1 terminal. Further to that, back the first day I installed this alternator, not having the push button switch on hand, I merely swiped the bare end of wire from terminal 1 across main terminal of alternator, coming from battery.
When it came to a switch for this, a neighbor told me he used a toggle switch, but ocasionally drained his battery forgetting to turn the switch off at the end of the day. Since I knew it only required the initial contact, I decided, why not a push button, one can't forget. What I like about the push button, alternators don't charge high amperage very long from starter use, if tractor starts quickly. I find myself looking at the amp gauge as I push the button, and if I didn't look within 10 seconds the amp gauge wouldn't tell me a lot. I could install a volt meter, but why, I've been getting along great with what I have. I do have a volt meter with aligator clips, and that serves me well as I can clip it onto any one of my 6 vehicles, anytime.
You are right, thankyou very much for bringing this up. When I installed these alternators 15 years ago, computers had not yet arrived at our house, thus there was no YT or diagrams of guys like Bob M. Never in my wildest dream did I think I'd ever be giving advice on how I did this. It was for my use only back in those days.
JMOR
11-16-2007 12:50:12
 Re: terminal with pigtail in reply to Hugh MacKay, 11-16-2007 03:02:57
All sounds good to me.
You have a nice day, now and enjoy another morning cup of coffee tomorrow!
Bob Kerr
11-14-2007 21:49:38
I know what you mean. I went to a show this summer and looked under almost every H and M at the place and there was a lot of them and I only saw 3 6v gennys there. One was a 12v genny and the rest were alternators, several were the Jap style, the rest of them were regular GM. My H has the 6v genny and I use it most every day with no trouble now, but went through a buch of problems when I first got the tractor since someone at the auction hooked up a 12v batt in it neg ground and cooked everything. Had to replace everything, some things twice since regulators made in India are junk.
old
11-14-2007 21:37:10
Alternators are just plain more reliable then gennys are. Takes less wiring to hook them up and they also cost about half of what a 12 volt genny will cost
Jim Broughton
11-14-2007 21:28:20
Scott; Probably because the old 6 volt voltage regulators were somewhat un-reliable. I believe you have tochange the regulator and the generator when going to a 12 volt set-up; an alternator has the regulator built-in internally, so it's simpler to install/convert. Some of those early regulators, like the one on my Cub are only glorified "cut-outs" and can be very troublesome. Hope this helps . Jim B.
terryjd
11-15-2007 11:00:12
 Re: Generator vs alternator in reply to Jim Broughton, 11-14-2007 21:28:20
I just changed my SC to a 12 volt system because of cost. Tractor battery would discharge when being used. Charged battery, had it tested, tested good. Followed the guide for trouble shooting a genny. I put on new voltage regulator, new amp guage, checked all wires. That lasted a few minutes, all of a sudden the amp guage went past the -20 and stayed there. Well now I needed another amp guage, so now I am in the hole for $80.00 by the time I buy another amp guage. And still don't know if VR was fried also or not. Genny must of had a problem or could have been the new VR. Well I just said to myself enough is enough time to go 12 volt. Had a 84 Buick that was going to the junkyard, and a decent 12 volt battery and alternator, pulled the alternater off it, bought a small pully for 5 bucks and put on the alt., eaiser then putting the pully off the genny onto the alt. Made the brackets, rewired it all with new wires except for the battery cables. Took me about 6 hours to do everything, I am not real quick at fabercating or wiring but got the job done. Now tractor starts, charges and if I have a problem not going to cost me $100.00 to fix it and maybe see that $100.00 in parts fried again. Seems to me I will save money in the long run and less headaches. JMHO
