Governor Trivia Question.
tmonton
11-19-2007 13:55:53
third party image
I am attaching an image from the governor linkage on my Super H Stage-II. Here is my issue.
My linkage ( broken ) is on the right side with the spring still attached.
As you can see the one on the left, an ordinary H or M linkage arm, is quite a bit different than the right side. I have tried both the H and the M governor with no luck.
I cannot read the actual part number on the linkage arm to help myself out either.
I am wondering now, is this the same one that is used in the 300 number series ? There is still only 2 weights on the clutch like normal ... not 4.
ejr-IA
11-19-2007 18:49:03
 Re: Governor Trivia Question. in reply to tmonton, 11-19-2007 13:55:53
H and 300 have the same part no. 6676DB
tmonton
11-19-2007 17:03:04
I do have a part number on the governor housing.
6634DD 7
It looks the same as all the other governors I've seen. I would rather replace a broken arm than the entire governor.
D Slater
11-19-2007 16:27:02
Arm and spring is aftermarket, never saw one like that before in a power governor, not like any tompson, rocket or M&W power governor I have seen. Some power governors only had 2 weights. Early M&W did also. Sometimes the weights will have letters and numbers on them to get a idea of who made them.
Willie R Adkins
11-19-2007 15:09:32
their is some differences will the spring lever mount if so you may have to synchronize the govenor to carburetor linkage don't really know just taking a stabb at it good luck also is their any tractor salvage yards where you are at that could look at another one to help out.
ChrisAS
11-19-2007 14:28:04
I worked on a lot of H,M SH,SM,300,350,400,450 never saw one with pins in it like the one you show. Don't remember what the M&W gov. had, never did like them anyway. The gov only had to weights.
