SM light lens
Mike Tetreault
11-24-2007 06:06:27
Does anyone know where I can get a replacement lens for my SM I would like to keep it 6 volt, I have ordered Part No: GC200) from this sight and tried another supplier as well, the lens is 4 5/8" and needs to be 4 1/2 "? Thanks Mike
STEWARTINPA
11-24-2007 08:02:41
 Re: SM light lens in reply to Mike Tetreault, 11-24-2007 06:06:27
IF YOU HAVE A BELT SANDER TURN IT UPSIDE DOWN ON YOUR WORKBENCH TURN IT ON AND SAND THE 4 5/8" LENS DOWN DON'T PUSH TO HARD AND KEEP ROTATING IT THIS IS HOW I WAS TAUGHT TO ROUND MIRRORS FOR TRUCKS IT WORKS WELL STEWART
RustyFarmall
11-24-2007 06:26:17
I will assume that your super M has the flatback sealed beams? If so, that sealed beam is available as an assembly only, the lens and the reflector do not seperate. The sealed beams are available in either 6 volt or 12 volt, and are authentic reproductions.
Mike Tetreault
11-24-2007 10:58:12
 Re: SM light lens in reply to RustyFarmall, 11-24-2007 06:26:17
Rusty, its a bulb and lens not a sealed beam? I would really like to keep it original. Thanks,
RustyFarmall
11-24-2007 12:36:49
 Re: SM light lens in reply to Mike Tetreault, 11-24-2007 10:58:12
Those sealed beams will come apart, but only after they have deteriorated or possibly rusted through from the backside. Yes, there is a bulb in there, but the lens is supposed to be sealed to the reflector and as such the whole thing becomes an assembly. The lens is not available seperately.
I guess there is a possibility that maybe the lights you have are some sort of aftermarket add-on deal, and are not original to the tractor?
Mike Tetreault
11-24-2007 14:48:09
 Re: SM light lens in reply to RustyFarmall, 11-24-2007 12:36:49
Rusty, I just went down to the tractor barm and did some investigating, it is a Guide Lens socket.
