560 Farmall fast hitch
Dennisn715
11-25-2007 09:22:53
I was wondering if some one can help me out? I bought a fast hitch for my 560 farmall and there is slop in certain parts when put together. I noticed there is copper bushings that are wore out. Can these be replaced anymore? If so, where can I purchase them? Thank you, Dennis
CNKS
11-25-2007 12:56:32
 Re: 560 Farmall fast hitch in reply to Dennisn715, 11-25-2007 09:22:53
I doubt if Case-IH has them -- their web site does not identify anywhere near all the obsolete parts, but you can try. I had my 460 fast hitch rebuilt, same problem as yours--$400+ if I remember right. Repair shop had trouble getting the bushings (a lot of them are brass), and had to build up some of the shafts. That wear is the main problem with fast hitch.
ejr-IA
11-25-2007 12:06:30
Case IH shows good numbers yet.Controll pivot 5227005r1,rock shaft 523708r1,lift arm 523092r1
Wardner
11-25-2007 10:31:28
If Case/IH doesn't have them, go to MSC, McMaster-Carr, Graingers, or your nearby bearing house. You can order bushings/bearings on the internet from these sources..
I don't recall any brass bushings on a 560 hitch. If there are any bushings, they are almost certainly steel. I take that back. There may be brass bushings in the rock shaft arms. Parts subjected to heavy pounding/draft loads will be steel.
