Regular
Roadhog
12-05-2007 19:40:53
Here is a picture of the Regular I found!!!
LJR
12-08-2007 07:30:27
 Re: Regular in reply to Roadhog, 12-05-2007 19:40:53
2-cents worth:
Governor looks like aftermarket conversion to variable-type. IHC had a conversion, but the linkage is different.
Brakes appear to be aftermarket, also. F-20 brake pedals are cast, as I recall.
Mag is F-4. Same base, different coupling, I think. Good mag, nice automatic impulse.
Seat is probably after WW II. Similar to the hydraulic-shock arrangement on late H, M, Super H and M.
Steven f/AZ
12-06-2007 11:42:52
Looks like one that could be cleaned up and left in original condition... Personally, I am finding more value to myself on tractors that are in original condition, rather than repainted... unless of course there is nothing left but rust.
moseed
12-06-2007 11:20:52
 Re: Regular in reply to MN Scott, 12-05-2007 19:40:53
Looks like foot brakes too!
Bob Kerr
12-06-2007 08:28:02
If it were mine, I might just clean it up and show it as it is! It was nicely "upgraded" in the past with the F4 mag and spring seat. Nice find!
James Williams
12-06-2007 01:17:25
If it was mine I wouldnt answer either,nice find.That tractor is a lot father ahead than mine.Wheels are worth a few hundred,motor loose-pricless,its worth more than a few hundred
jimmy
SproutW
12-05-2007 19:42:41
Nice!! You going to take the hunk of metal home and start a restoration?
Roadhog
12-05-2007 19:42:27
Another one
Roadhog
12-05-2007 19:43:45
 Re: Regular in reply to Roadhog, 12-05-2007 19:42:27
Yep, Its a regular!!!!
Roadhog
12-05-2007 19:49:26
 Re: Regular in reply to Roadhog, 12-05-2007 19:43:45
Here are some pics', I got a better look today, rad empty, crankcase full of oil, not water, tires shot!? But hey look at the second picture, there's the crank laying on top of the tank, and gueess whut????? SHE"S NOT STUCK and has GOOD compression!!!!! !!!!! I tried to call the owner to make an offer but he's not answering!!!!! !!
