farmall h not runing
john cranston
12-08-2007 19:53:18
farmall h not runing it pops flood out gas come out the carb replaced ponits wires cap plugs rebuilt carb help
john cranston
12-16-2007 07:06:05
 Re: farmall h not runing in reply to john cranston, 12-08-2007 19:53:18
ad to my h if i pull choke and keep cranking sound like going to start then let of choke then it stops thanks john (nj)
john cranston
12-20-2007 17:02:27
 Re: farmall h not runing in reply to john cranston, 12-16-2007 07:06:05
fixed. found generator not working put jumper wire from battry to swich and it start with help from (jim) need to get generator tested thanks john
minnmeyer
12-11-2007 16:08:34
Sounds like the same problem I was having with my 41 H.Had lots of advice,however very little on this sight.(I was Very disappointed)Anyway I went through the carb completelywith carb kit #CS10 HV used old needle,all brass,not the neopreme tip one.Made sure float was set right and it runs like a top now.went through carb many times before putting this kit in it with no luck.Hope this works for you,good luck,let us know.
riverbend
12-09-2007 05:57:21
By all means, if you replaced the points, reset the timing.
It is possible that you are just flooding it. When you try to start you tractor, just crank it over a couple times with the choke out. Then open the choke and try it again.
Greg
glennster
12-09-2007 04:45:40
if you have gas leaking out the carb air intake,i'd look real close at the float. remove the float from the carb and gently shake it, listen for gas sloshing around inside,could be a hole in the float. next, check the float to be sure its not catching or rubbing on the carb bowl. its a pretty tight fit in there and if the float is hanging a little crooked, it can get hung up on the side of the bowl and flood. also check the carb bowl gasket and see if its sticking too far into the bowl and holding the top of the float down. if all looks well, put carb back on, take bowl off, turn fuel on just a little, and gently lift the float to see if it shuts off the fuel. if it doesnt, there is a needle and seat problem or a float level adjustment problem.
El Toro
12-09-2007 03:56:03
Make sure you plug wires are not crossed. They should be in this firing order as you view the cap. Hal
2-1
4-3
Janicholson
12-08-2007 20:55:10
Andy is on to the possible float issue. Check the needle and seat for its ability to stop fuel when demand is low (idle) and when stopped. If it leaks, it may need to be replaced, or adjusted. The float must not ride against the bowl, nor stick down, nor sink from fuel in it. Always shut off the fuel at the tank when not running the tractor (even for 5 minutes) JimN
Andy Martin
12-09-2007 05:32:09
 Re: farmall h not runing in reply to Janicholson, 12-08-2007 20:55:10
Hal has a point too, lot's of goo dtractors will trickle gas out the carburetor when the wires are crossed. And the wires were replaced. Of course the carburetor was disassembled, too.
And after the fuel line has been removed and replaced, chances are good that there is trash in the needle seat.
john cranston
12-08-2007 21:15:48
could the timming have any thning to do with not runing or do you think it carb
Andy Martin
12-09-2007 08:55:20
 Re: farmall h not runing in reply to john cranston, 12-08-2007 21:15:48
Pay attention to Hal's message. It is easy to get the wires crossed when changing them, we've all done it. Make sure the wires are on right.
Andy Motteberg
12-08-2007 21:25:27
If you are getting gas running out of the carb, it is most likely a carb problem. If your dist/mag has good blue spark, then the ignition is fine. Make sure your spark plugs are clean and gapped correctly too.
Andy Motteberg
12-08-2007 20:23:10
Is the carburetor adjustment set correctly? Is the carburetor float level set?
