51 Farmall C oil pump removal
Greg 2010
12-11-2007 19:24:05
I am rebuilding the engine on my 1951 Farmall C. I am trying to remove the oil pump. There are two bolts that I removed and thought this would let the pump slide out but it seems to be stuck What do I need to do to remove the pump any advice would be appreciated.
teddy52food
12-12-2007 06:41:03
 Re: 51 Farmall C oil pump removal in reply to Greg 2010, 12-11-2007 19:24:05
If the engine has been stuck for a while with water in the pan, take the bottom cover off the pump. the gears may be stuck. If not a light tap should bring it down.
El Toro
12-12-2007 03:53:48
Hit it with a rubber mallet. It could be some sludge making it stick. Hal
ScottyHOMEy
12-11-2007 19:36:48
Not sure what to advise apart from maybe some spirited wiggling. There's nothing holding it in place apart from those two bolts. Perhaps a little very LIGHT tapping with a SMALL hammer, but NO walloping.
Is the engine otherwise free? Perhaps turning it a bit might help free up the gear on the pump????
