remote hydraulic add on kit for a 424 int. tractor
stan slagowski
12-18-2007 10:16:32
I am looking for a remote hydraulic kit for a 424 international tractor. I know they made one but as of now can't find one or get a reply to any of my inquiries. can any one help in any way thanks
PaulW_NJ
12-19-2007 19:46:42
 Re: remote hydraulic add on kit for a 424 int. tractor in reply to CNKS, 12-18-2007 10:16:32
stan slagowski said: (quoted from post at 11:16:32 12/18/07) I am looking for a remote hydraulic kit for a 424 international tractor. I know they made one but as of now can't find one or get a reply to any of my inquiries. can any one help in any way thanks
third party image
This is the parts schematic for the remote hydraulics for the 424. It's listed as IH part # 391551R91, worth a try, but likely not available anymore new, but I found remote breakaway couplings for my 340U at JP Tractor Salvage. I just removed the plugs on the bottom of one of my hydraulic control valves, and ran steel tube (or hose) back to the breakaway couplings. If your hydraulic valve is already connected to something else, you'll need a three way, or isolation valve selector.
Gary in Mozarks
12-19-2007 17:44:38
 Re: remote hydraulic add on kit for a 424 int. tractor in reply to stan slagowski, 12-18-2007 10:16:32
[ I have a 424 diesel with the remove hydralic valves on the left side of the seat. The only other one I have seen is in the manual and I have looked at alot of 424's Mine is missing the 2 levers that go under the seat. I have tried for years to find those levers without success. I keep saying I am going to make them but I havn;t done it and now I have it for sale. Good luck in your search and let me know if you find anything Gary
Fromjb2
12-18-2007 16:26:51
Stan, are you looking for the single acting remote auxiliary hydraulic outlet that used the the aux valve and 3pt hitch control lever to operate?
These remote hydraulic outlets were common on B414,434,444 and 384. I believe the 424 uses the same frame so one from the above models should fit.
JimB
Nat 2
12-18-2007 13:03:35
 Re: remote hydraulic add on kit for a 424 int. tractor in reply to Gary in Mozarks, 12-18-2007 10:16:32
What do you mean by "remote hydraulic kit?"
Does this tractor not have hydraulics?
Your best bet will be to find a 424 in a salvage yard that has the parts you need, and strip them off. Or, perhaps you'll find a salvage yard that has already stripped them and has them on a shelf.
