How to remove Farmall H piston sleeves
Diocona
01-05-2008 09:31:46
I need help?
How can I get the piston sleeves out of the motor?
Are they wet or Dry?
Please help me!!!
jason m
03-17-2008 09:04:40
 Re: How to remove Farmall H piston sleeves in reply to Diocona, 01-05-2008 09:31:46
take a muffler clamp u bolt slide it into the sleeve from top and weld it right to the sleeve but dont burn through using a new rod which is nice and long run up and down the inside of the sleeve to make heat you dont really have to run a bead of weld using a pipe drive the sleeve out from bottom using a hammer they pop right out
glennster
01-05-2008 18:00:58
if you dont have a sleeve puller, take the block to a machine shop and they can pull them for you. here are a couple of my sleeve pullers, one store bought, two home made
third party image
third party image
third party image
gene bender
01-05-2008 13:29:34
You will need a sleeve puller and get a manual they will tell you the procedure. The I@T is a good one cause if you dont know how to pull sleeves there will be other things you need to know and that manual gives all the specs and how to do everything.
IndianaRed
01-05-2008 12:59:05
Dude, learn to use to archives here. That question has been asked and answered hundreds of times, and all the answers are at your fingertips. I learned more from there than anywhere.
Good Luck,
Brian
RustyFarmall
01-05-2008 12:58:05
They are dry sleeves. A sleeve puller is the best. Most other methods have a strong chance of damaging the cylinder walls. The welding method does have merit, but only if you are experienced with the welder.
John M
01-05-2008 11:12:10
if youre not going to reuse them, and have a welder, runs a bead on each side, just enough to get it hot not enough to weld it to the block, after it cools they usually slide right out for me.
Floyd A tn
01-05-2008 10:33:27
 Re: How to remove Farmall H piston sleeves in reply to georgeky, 01-05-2008 09:31:46
You can use a hydraulic jack a flat steel plate to get them started.. If you can get them up a half to three quarters of an inch, they will usually come on out with out a great deal of difficulty. I had a machine shop to make me a plate that fits snug on the inside of the sleeve and is 5000 shy of the same diameter of the outside of the sleeve.. You can push the sleeves on up into the block if it doesn't loosen up by the time the sleeve gets flush with the bottom of the block.
Good luck on getting them out.
Nebraska Cowman
01-05-2008 10:08:45
The sleeves are dry and a snug press fit. Are the pistons stuck in them?
M5G
01-05-2008 09:43:34
They are wet sleeves.
To get them out you will need a sleeve pulling kit and pull them from bottom up. The bottom of the sleeve puller has a built in flange to catch the sleeve without doing damage to the sleeve. Of course the pistons need to be removed for the puller to be used.
You might want to use some PB Blaster or any other rust type solvent -- kerosene works too to loosen the rust...tap with a wooden block on top of the sleeve after lubcating to get the rust to break loose (it might be good to even soak for a couple days before trying to remove them)
Lots of Luck! Go slo and easy!
Kristof
01-05-2008 09:41:25
Hey, the sleeves on the H and Super H are dry ones (according to my I&T Shop manual).
Normally they are removed by using a special puller (IH puller SE 1213). But you can easily reproduce one of these. With a couple of round plates and a threaded rod.
You can also try and knock em out from the bottom up with a hammer, but I don't recommend this. Because you can damage the sleeve excessively wich makes it even harder to get it out.
Kind regards
