Please give me your opinion on this...
Hansen
01-06-2008 09:33:32
http://www.ksl.com/?nid=218&ad=2434303&cat=&lpid=
Darald
01-07-2008 21:26:34
 Re: Please give me your opinion on this... in reply to Hansen, 01-06-2008 09:33:32
The body on a 300 is all red. The white inserts and grill were started with the 350 series. The rear rims are the galvanised color, often painted a dull aluminum color, fronts are all red.
Dellbertt
01-06-2008 12:27:00
I"ve got two IH300U that work everyday for 10 years. When I first got them I put new screens in the hydrualics and thats about it. I think they are a good tractor. Power steering is important to have in my opinion. It sounds like a good deal if everything is as advertised.
Pat-CT
01-06-2008 09:49:25
TA is torque amplifer it gives you an imbettwen spped of the gears or a high a low range you can use the TA on the fly its expensive to fix so its verry important that it works properly
Janicholson
01-06-2008 09:40:13
If it runs well and the steering is good (not loose or binding) and if it has working hydraulics that lift the tillage equipment, it is a steal. It is painted in the livery of a 350. But that was common practice to make them appear more modern. (it could be a 350, check the engine size on the block by the oil filter.) Nice find if as shown. JimN
Steven f/AZ
01-06-2008 09:39:42
Other than the paint being wrong, it looks like a good tractor and a fair deal with the equipment included. I believe the new tires and included equipment would be worth over half of the asking price. It would be nice to know if the TA and IPTO work properly...
Hansen
01-06-2008 09:44:41
 Re: Please give me your opinion on this... in reply to Steven f/AZ, 01-06-2008 09:39:42
Sorry, what's TA?
Janicholson
01-06-2008 09:52:54
 Re: Please give me your opinion on this... in reply to Hansen, 01-06-2008 09:44:41
A TA is a gear reduction system allowing the tractor to be shifted down 30% (approximate) by pulling a lever on the left side of the operating area left of dash, and big. The lever operates the system by clutches and allows 10 speeds forward, and 2 reverse. To use it one just pulls it back rapidly to lower the ratio under load (no foot clutching needed) or putting it forward (rapidly) to go to direct drive.
If your tractor does not have it (very possible) it may not have a live PTO either. That would make it 1000.00 overpriced (opinion). If the TA does not work, it is OK, they can be replaced for about 700 plus labor. JimN
