farmall h hydraulic
alpo
01-06-2008 16:55:42
does any one know how much oil go in the hydraulic ? and dose the rearend take 90 wait oil
williamf
01-07-2008 02:24:19
 Re: farmall h hydraulic in reply to alpo, 01-06-2008 16:55:42
Walmart has a cheap 30wt non-detergent motor oil (says on the bottle not to use in modern engines) that I use in my H's hydraulics. I've been told that it matters to use the non-detergent because it doesn't have a problem with foam and that 30wt will develop better pressure in the old system than the lighter hydraulic oil.
Good luck, Wm
Scott Rukke
01-06-2008 17:07:00
The belly pump reservoir holds approximately 6 quarts of 30w oil. I use 90w in my tranny. It takes a lot of it too, about 6 gallons.
NBAllen
01-07-2008 11:03:04
 Re: farmall h hydraulic in reply to Scott Rukke, 01-06-2008 17:07:00
Make that 7 gallons - per the book.
alpo
01-06-2008 17:26:00
is that 30w hydraulic oil
CNKS
01-06-2008 17:28:48
 Re: farmall h hydraulic in reply to alpo, 01-06-2008 17:26:00
That is 30W motor oil. You can use hydraulic fluid (Hytran or equivalent), but it is more likely to leak if the seals are weak.
