Farmall A front pivot pin
Tims-A
01-08-2008 18:16:20
I'm removing (attempting) the front axle assembly to do several repairs. I have loosened the clamp bolts (steering gear casting) on each end of the pivot pin. I can move the pin about 1/8th inch each way with a persuader, then it stops solid. Any ideas on how to remove this? Could it be frozen in the front bushing?
Thanks,
Tim
gene bender
01-09-2008 03:25:40
 Re: Farmall A front pivot pin in reply to Tims-A, 01-08-2008 18:16:20
If you have both bolts out it should move but due to lack of grease the pin can be worn enough to be hard to remove. That pin is under cut where it rides on the pivot only the ends are full size. When you get it removed and need a new one i have some.
Hugh MacKay
01-09-2008 02:29:45
Tims: Andrew is right, what you are calling clamp bolts, actually cut close to 3/16" through a notch in the pin. Slow down a bit Tim, looks things over a bit more closely before grabing the hammer.
Tims-A
01-09-2008 15:56:10
 Re: Farmall A front pivot pin in reply to Hugh MacKay, 01-09-2008 02:29:45
Hugh,
Thanks again, removing the bolts completely was the answer. You were right on both counts, looking a little closer too.
Tim
Andrew Z
01-08-2008 19:11:59
Did you take the bolts out all the way out?, there are groves in the piviot pin that the bolt lock into. If there out then theres nothing else that can hold it.
Andrew
Tims-A
01-09-2008 15:57:58
 Re: Farmall A front pivot pin in reply to Andrew Z, 01-08-2008 19:11:59
Andrew,
Thanks for the heads up, thats what I needed.
Tim
Hendrik
01-09-2008 02:23:48
Andrew Z is correct; you need to remove both bolts fully. Even then I had a hard time HAMMERING the pin out. It seemed pretty loose but still took quite some effort to remove and the pin didn't even have wear grooves or nicks...
