one more 12v question
Pat-CT
01-09-2008 18:06:55
do i need a resistor even with a magneto
NDS
01-10-2008 10:07:54
 Re: one more 12v question in reply to Pat-CT, 01-09-2008 18:06:55
The magneto produces its own spark and is no way connected to tractor electrical system at least in stock form. Some magnetos have gone bad for various reasons and have been converted to use battery ignition with external coil in this case you are only using points in magneto if this is what you have you will need resistor for 12 volt tractor. Some coils have built in resistor and do not need the external resistor.
Pat-CT
01-10-2008 09:08:23
sorry soundguy if the 16 year old dosent get it
Yugrotcart
01-10-2008 14:16:15
 Re: one more 12v question in reply to Pat-CT, 01-10-2008 09:08:23
Pat,
If the magneto is still functioning like it shoudl, producing its own power, it doesn't need a resistor. The only wire leading from the mag, besides the plug wires, will be the ground wire for shutting off the tractor.
Here's a link for you to have a look at with different diagrams.
Hope this helps,
Paul
Janicholson
01-10-2008 07:45:53
The magshould not be "plumbed into any voltage of any type. Is grounded to shut off the tractor. Any battery voltage on the mag is Very bad for it. The stop button grounds the mag, that is it. JimN
soundguy
01-10-2008 05:32:05
I'm framing this one to hang on the wall!
thanks!
soundguy
Andrew Z
01-09-2008 18:09:36
nope
Anderw
