rear tires
dennis repaal
01-11-2008 09:13:45
guys- i know this isnt the site to post this but im looking for 11.2-36 rear tires for my c farmall.hopfully in good shape. thank-you dennis
Scott Rukke
01-11-2008 19:43:19
 Re: rear tires in reply to dennis repaal, 01-11-2008 09:13:45
If you're in an area where Les Schwab operates I just bought a set for $219 each and that includes mounting which took 2-3 guys 2 hours. They are Harvest King.
oldiron29
01-12-2008 03:36:02
 Re: rear tires in reply to Scott Rukke, 01-11-2008 19:43:19
Scott, I was told harvast king did not make 36" rear tractor tires. oldiron29
Scott Rukke
01-12-2008 07:34:38
 Re: rear tires in reply to oldiron29, 01-12-2008 03:36:02
I guess mine are 38's. Brain fade. Not sure if they have the 36's but I would think they have another brand if not HK's.
plowboy 14505
01-11-2008 17:13:09
i have some 11.2-38
James Williams
01-11-2008 17:01:24
Bobs Tire in Berkley springs&Martinsburg WV has them for around 250.$ each
oldiron29
01-11-2008 16:17:58
Dennis, Tucker tire in TN. just listed on ebay 12.4x36 tires brand X 480.00 a pair 125.00 for shipping. That is the lest expensive new 36" tire I have seen. oldiron29
Maark
01-11-2008 13:53:03
Check Ebay# 300187895272 located in Wi. 4hrs left at 4:06 pm
oldiron29
01-11-2008 13:34:27
Dennis, There is a guy in Mt. Airy MD. That has an ad on criagslist for A,B,C,and cub parts
I emailed him and he said he had a set of farmall c 36" tires. Try looking on craigslist tractor tires. oldiron29
James Williams
01-11-2008 14:24:57
 Re: rear tires in reply to oldiron29, 01-11-2008 13:34:27
Old Iron,I sure would like his address,I need a set of 36s
jimmy
oldiron29
01-11-2008 14:51:50
 Re: rear tires in reply to James Williams, 01-11-2008 14:24:57
James, Here is an add on craigslist for 4) 36" tires. sale-523478805@craigslist.org
also here is the phone# Allen Dorsey 410-596-5559 Maryland
He said he had A,B,C, and cub parts He said he had 36" farmall C tires. If you don't need them all pass this on to Dennis. Oldiron29
RustyFarmall
01-11-2008 10:42:33
If you're looking for used tires in great shape, you might be looking for a very long time. Once in awhile, if you do your research, you can find some really great deals on brand new tires.
dennis repaal
01-11-2008 12:33:08
 Re: rear tires in reply to RustyFarmall, 01-11-2008 10:42:33
guys- why is it every thing i get into the parts are hard to fine or so expenseive you cant afford them. including my wife. there i got that off my chest. new rear tires 300.00 plus thank-you dennis
oldiron29
01-11-2008 13:41:15
 Re: rear tires in reply to dennis repaal, 01-11-2008 12:33:08
Dennis, I got a quote for firestone 11.2 x 36 new 385.00 plus tax each thats more than 1/2 what I paid for the running F-20. oldiron29
RustyFarmall
01-11-2008 13:33:51
It does seem to get a bit expensive doesn't it?
Just keep in mind that you only have to buy new tires and fix up that old Farmall one time, and it will probably out-last you.
There are many other hobbies that are even more costly, but the cash outlay is not nearly as great at any one time, so folks involved in those hobbies do not consider them to be expensive.
As an example, what does it cost per ticket to attend a nascar event? And how often do some folks do that in one year? Add it all up, and it makes this old tractor hobby look pretty cheap by comparison.
Andy Martin
01-11-2008 17:17:51
 Re: rear tires in reply to RustyFarmall, 01-11-2008 13:33:51
It should also remind everone how important the quality of the tires is on a tractor you are considering purchasing.
I often wonder how many of the rich collectors discard perfectly good tires to get a matched set or get rid of some weather cracks. There needs to be an exchange set up for them.
Kind of like cracked H heads.
teddy52food
01-11-2008 14:43:26
And after attending an event all you have is memories, whereas you still have your old tractor with new tires.
