farmall H
JayinNY
01-15-2008 17:10:42
Can any one tell me why my farmall H wide front has the steering rods behind the frone axle, towards the seat rather than out in front? All the farmalls I have seen have the rods in front of the axle. Is mine a add on front end? thanks j
Andy Motteberg
01-16-2008 11:06:15
 Re: farmall H in reply to JayinNY, 01-15-2008 17:10:42
The early models had the tie tods out front, that was a problem because they would bend or break if you hit something on the front. Later, IH moved the tie rods behind the wide front end. That was a improvement. You could possibly have a aftermarket Shwartz wide front, the tie rods were behind on those front ends.
Steven f/AZ
01-16-2008 07:34:33
Looks like a Schwartz to me, the lighter-duty ones had the same wheel/hub as IH front ends with the 3-bolts.
Here's your picture:
third party image
jayinNY
01-16-2008 11:40:04
 Re: farmall H in reply to Steven f/AZ, 01-16-2008 07:34:33
Thanks Steven, I'll just leave it at that. Im glad to find out some info about the old tractor. Thanks again. jay
Steven f/AZ
01-16-2008 06:06:24
 Re: farmall H in reply to teddy52food, 01-15-2008 17:10:42
Jim J said: (quoted from post at 20:33:53 01/15/08) The tie rods are like a Speeco or a Nordan. How are the steering arms held on the spindles? Are the steering arms splined or keyed to the spindles?
Beats me! Never had that apart. The guy I bought it from told me that he purchased it from an IH dealer and was listed as "Schwartz" on the invoice and told it was a Schwartz. If I remember correctly, what's left of the tag has some part of the name on it yet, too.
Either way, it steers easier and is way stronger than the IH front with tie rods in front. And I can borrow any implement wheel/tire if I get a flat!
Steven f/AZ
01-15-2008 18:42:55
 Re: farmall H in reply to D Slater, 01-15-2008 17:10:42
Jim J said: (quoted from post at 18:35:12 01/15/08) I hate to tell you but your front is not a Schwartz it looks like a Speeco.
Bought parts for it, it's a Schwartz heavy duty.
Jim J
01-15-2008 19:33:53
 Re: farmall H in reply to Steven f/AZ, 01-15-2008 18:42:55
jayinNY
01-15-2008 17:34:01
Steven,I will have to look at mine again. But it does like like the one you show in the picture. As you and CityBoy said it could be a swartz? Im assuming some one put this on a narrow front end tractor, right. It is not factory from IH. Like CityBoy said it is a better front end, I have seen guys who hit a tree or something and break the rods out front. thanks Jay
Steven f/AZ
01-15-2008 17:23:48
IH factory type wide front would be similar to this:
third party image
Started around about the time of Super MTA, 300, etc.
Schwartz looks like this:
third party image
third party image
Speeco wide fronts are similar to the Schwartz... there should be a tag on the aftermarket wide fronts.
jayinNY
01-16-2008 07:11:31
 Re: farmall H in reply to Steven f/AZ, 01-15-2008 17:23:48
Steven, I see that yours has the implement hub, like you you can use any tire. Mine has ths farmall style rims, with the 3 bolts that bolt it to the inner rim! So maybe a later IH front end? I will see if I can get some pics of it. And look for a tag on it. I put a pic on the tractor pictures on this site, but you cant see it to well.
Jim J
01-15-2008 17:35:12
CityBoy-McCoy
01-15-2008 17:18:54
Jay:
It could be you have an aftermarket, like a Swartz brand. Or, it could be that you have the newer IH style which was used on the Super H, 300, 350 etc. Either is generally considered better than the old style with the tie rods out front. mike durhan
Al in Mn
01-15-2008 18:55:04
 Re: farmall H in reply to CityBoy-McCoy, 01-15-2008 17:18:54
The wide front could also be Norden, we have one on a 560, the company is no longer ing business.
