Order Farmall Cub Parts Online
Cub Hydraulic Pump Seal
Ron Weber
01-15-2008 20:32:30
Gentlemen and Ladies, I need help. An I am not talking about the head shrinking kind either!
I have a Cub low-boy that has a hydraulic pump mounted on the engine-you know for the touch control. I recently rebuilt the tractor after it sat for 7 years. The hydraulics had always worked well, but since the rebuild I have had to add oil to the hydraulics twice. I went to use the tractor last weekend only to find out that there was no hydraulics. Hmmmm. So I checked the dip-stick and sure enough the oil level is 1" higher than full---the seal is shot on the pump and leaked all that oil into the engine. So, I took the pump off and found that there is a leather seal for the pump and it's dried up and cracked. WHERE do I find another seal? Can I buy one? Should I bored it out for a modern rubber press in seal? Anyone know what to do?
As usual, thanks for saving my blood pressure. Ron in Michigan.
gene bender
01-16-2008 09:26:39
 Re: Cub Hydraulic Pump Seal in reply to Ron Weber, 01-15-2008 20:32:30
Just take the old seal to any parts house and they will get you a new one. If the shaft is worn where the seal fits you will need a speedy sleeve. Take the pump along so they can get the correct speedy sleeve as you probably need one.
EZ
01-16-2008 08:03:31
third party image
third party image
Here are couple pics.
You will need the correct pump number when ordering kit. Good luck.
Dave from Texas
01-16-2008 06:47:55
The service manual shows two seals. The leather seal is labeled as "Old Type". The new type shows as an "O" ring. I am doing the same thing. I have not taken mine off yet. I have been draining the oil out of the engine and putting it into the hydraulics. Trying to get through the winter garden season!
banjo
01-16-2008 05:21:13
farmall.com has sponsors that sell cub parts also.
should be a number on the pump so you can get the right parts.
El Toro
01-16-2008 04:08:02
I don't have a breakdown on the Cub's pump, but this one may be similar. It's fairly common for these old seals to become harden and then wear a groove in the shaft. Napa has speedi-sleeves and Case/IH should have them too. The same thing happens to the hub on the crankshaft pulley and will cause an engine oil leak and a speedi-sleeve
will cover this worn area too. Hal
third party image
PS: Speedi sleeve on a pulley hub
third party image
Gene
01-15-2008 20:39:15
Rebuild kits are available from your IH dealer. The front seal is sold seperately from the kit.
You will also need to know which hydraulic pump you have. I believe there are two different pumps available
