Springtooth grass seed drill size for a tractor -656/2656/6
bc
01-30-2008 08:59:10
Hi, Skyharbor just asked one of my questions I always wondered about with a disk. I have a (still not sure) industrial tractor with a c-263 gas engine and prob a 2656, 656, or 606. It has a loader with a backhoe on the back. I suppose this one would also pull a 12' tandem disk.
If I want to add on a springtooth to work the horse corral and also smooth out some pasture ground and prepare some pasture for overseeding with brome, what is the max size springtooth that would work? Also what is the max size drill that can be used for seeding brome or alfalfa for that matter?
We have an old steel wheel grain drill that has been sitting out by the barn and the hopper still looks good. It is probably about a 12 footer or so. Could that be fixed up to plant brome and if so what spacing does brome require?
My Mother-in-law, besides the pasture & crp, has about 90 some acres of crop ground rented out that sometime I would be tempted to turn into a haying operation someday provided I had my own swather & baler.
Janicholson
01-31-2008 06:41:04
 Re: Springtooth grass seed drill size for a tractor -656/26 in reply to bc, 01-30-2008 08:59:10
The tractor could pull a springtooth harrow of 20' width. (assuming the hoe was taken off etc). The spring tooth pulls pretty easy and is only limited by reasonable size on smaller plots.
Discuss grass seeding with your extension agent. Things are so different across even one county/and soil type that general info is marginal.
On the Drill, The shoes, listers or sweeps that open the seed depth may be worn rusted or trashed. Seed drop tubes and gear drives for agitators and measuring flow rates can also be frozen. If it is 20 years in the same spot, it may take a phenominal amount of work to make it operational. JimN
