M MAIN BEARINGS
Buck E
01-31-2008 07:40:28
THE ENGINE IS NOT IN BAD SHAPE , BUT WHILE I HAVE IT DOWN ,I WANTED TO PUT NEW MAIN BEARINGS IN.COULD YOU CHECK WITH PLASTI GUAGE? DON'T HAVE A MICROMETER. THANKS, BUCK E
ihc49er#2
01-31-2008 12:27:55
 Re: M MAIN BEARINGS in reply to Buck E, 01-31-2008 07:40:28
yes you can check it with plastiguage . proper way is to have engine out and upside down on stand .unbolt cap and install plastiguage. use 3 pieces 1 on top and the other 2 90degrees from the top one . then torgue to spec. and remove cap if your crank is out of round it will show here.new spec would be like .0015 to .002 for example.your used readings could be .002 up to .008 and all 3 srips showing diff. readings. doing this you will see how mu ch wear is on the crank and tell the story if it has to come out and get ground.hope this helps you out.thats why i am looking for a WK40 engine. the crank has like .009-.012 wear on it .just impossible to find a set of main brgs.unless i get the old ones rebabbited, but thats big money.anyone have a set let me know.
steelfronts
01-31-2008 14:13:34
 Re: M MAIN BEARINGS in reply to ihc49er#2, 01-31-2008 12:27:55
I have a set of standards but that wont help. I may have some worn 020s that could be installed and then line bored to 010 or what ever your crank cleans up at.
Chuck's Repair
01-31-2008 08:30:17
Yes, but take the weight off of the crankshaft so you don't get a false reading.
Chuck
Bob Farrell
01-31-2008 08:50:50
 Re: M MAIN BEARINGS in reply to Chuck's Repair, 01-31-2008 08:30:17
Chuck - I don't understand your comment. Please explain to me. I'm trying to learn. Thanks ! bob f.
Janicholson
01-31-2008 09:01:06
 Re: M MAIN BEARINGS in reply to Bob Farrell, 01-31-2008 08:50:50
Plastigauge is a thread of polymer that is squished in the clearance of a journal bearing to chack clearance. (It assumes several things are true and is good only if the journal is round and straight, and th rod (or cap on the main) is round and straight, and the insert is correct and has proper crush).
The crankshaft weight is heavy enough to flatten the material and give a bogus reading unless the crrank is held up into the block. during gauging.
Remember it is a guestimate of roundness and servicability, not a great way of measuring clearance or servicability on used parts. JimN
Buck E
01-31-2008 10:59:40
 Re: M MAIN BEARINGS in reply to Janicholson, 01-31-2008 09:01:06
JIM N I THINK I SHOULD REALLY USE A MICROMETER THEN. IS THAT CORRECT? ARE THEY EXPENSIVE? THANKS FOR THE INFO EVERYONE . BUCK E
Janicholson
01-31-2008 11:08:04
 Re: M MAIN BEARINGS in reply to Buck E, 01-31-2008 10:59:40
The problem with a mic is that the crank must be out of the block. If it was running well, has oil pressure, and no knock, putting bearings back in it that match the inserts removed will work fine. The shell should be marked with Std (standard), or .002 etc. undresize. JimN
Wayne from MN
01-31-2008 12:32:38
 Re: M MAIN BEARINGS in reply to Janicholson, 01-31-2008 11:08:04
I have a set of .002" bearings that we tried to put in a '54 SMTA. The old ones were marked .002" so just replaced them. For what ever reason they tightened up too much on the outer edges of the new bearings and the crank was too tight to turn over. So, we pulled the crankshaft out, took it to the local machine shop and had it reground. Now with 010" undersise bearings it turns freely.
Make an offer if you are in need of some .002" bearings.
Email is open.
