Beware using hydraulics in very cold weather
Jimer
02-02-2008 16:13:40
A week or so ago I was going to use my 300u after a very cold spell and none of the hydraulics worked. Think I got it fixed tonight.
My guess is the hydraulic fluid (a generic for hy-tran which I purchased from my Case/IH dealer), got so thick that when the pump tried to draw fluid it crushed the strainer in the hydraulic reservoir, as it couldn't get hydraulic fluid through the strainer.
Anyhow, straighened out the strainer and put in lighter hydraulic fluid and all works again. Just wanted to through out a word of caution as I haven't seen this problem discussed on here.
Jimer
David Goode
02-03-2008 08:57:58
 Re: Beware using hydraulics in very cold weather in reply to Jimer, 02-02-2008 16:13:40
I notice when I Shovel snow with the 2000 Loader on my Super M in colder weather it makes a "grinding" sound. Finally found out that I need to "warm up" the hydraulic fluid before use, so I'm looking at buying a magnetic heater for the oil reservar to keep it at least 50 degreese in colder weather. -David Goode Coggon, IA
Allan In NE
02-03-2008 05:18:53
You haven't seen it discussed on here because it isn't much of a "problem". People use hydraulics in sub-zero temps all the time.
Just keep the oil and filter/screens clean.
Allan
mkirsch
02-02-2008 18:29:16
 Re: Beware using hydraulics in very cold weather in reply to Hugh MacKay, 02-02-2008 16:13:40
Where did you get "thinner" hydraulic fluid? HyTran only comes in one viscosity.
It's true hydraulic fluid, like any oil, gets thicker in the cold. But if it gets so thick that it damages the system, it's not the right kind of oil.
Jimer
02-02-2008 19:48:17
 Re: Beware using hydraulics in very cold weather in reply to mkirsch, 02-02-2008 18:29:16
I purchased the low viscosity-winter weight hydraulic oil at Farmers Union - Cenex. I know it isn't equivalent to hy-tran, but I needed something that would work, NOW! Hope I do not live to regret it.
El Toro
02-03-2008 03:48:06
 Re: Beware using hydraulics in very cold weather in reply to Jimer, 02-02-2008 19:48:17
You need to use Hytran or HyGard. Hal
kossuth
02-02-2008 17:31:13
 Re: Beware using hydraulics in very cold weather in reply to randy hall, 02-02-2008 16:13:40
Jimer said: (quoted from post at 17:13:40 02/02/08) A week or so ago I was going to use my 300u after a very cold spell and none of the hydraulics worked. Think I got it fixed tonight.
Jimer
I kinda doubt that it was the thickness of the fluid alone. You may have had some condensation in there that froze up also. None the less I'm glad you got it all straighted out.
