Building up H shifter lever
neblinc
02-04-2008 07:31:00
What should I use to build up the end on my shifter lever. I have a torch & mig and want to know if I should use steel or bronze or something else when I build it up. I am an amateur welder, so it may take me a few tries :wink:
Randy
GordoSD
02-04-2008 16:26:10
 Re: Building up H shifter lever in reply to neblinc, 02-04-2008 07:31:00
Like any job, preparation is the key. Put that shifter in a vise and get your die grider or hacksaw and cut a groove about 1/16 inch deep in the center of the edges you are going to build up. This might be a job for a Dremel tool I own and have never used.
Gordo
neblinc
02-04-2008 12:28:24
 Re: Building up H shifter lever in reply to old timer, 02-04-2008 07:31:00
glennster said: (quoted from post at 15:33:59 02/04/08) randy, i have a couple stick welders, c'mon over and borrow em anytime!!!
Gee thanks Glennster, be over in 15 minutes :wink:
Randy
neblinc
02-04-2008 10:59:58
I don't own a stick welder, so I will use the mig.
Thanks Guys!
Randy
glennster
02-04-2008 11:33:59
 Re: Building up H shifter lever in reply to neblinc, 02-04-2008 10:59:58
NawlensGator
02-04-2008 10:53:00
6010 root pass, grind clean, overlay with 7018.
Nebraska Cowman
02-04-2008 10:03:21
I always just built them up with a stick welder. The same sticks we used for eveything else, I don't know, they are tanish grey and about a foot long. I like 5/32 the best. Anyhow, I sent you a pic of what a good shifter looks like.
Janicholson
02-04-2008 08:39:08
I agree with using steel. 6013 or 7014 will work. Mig may use milder filler than SMAW. JimN
Bob M
02-04-2008 07:43:42
Randy - On my Super H I used the arc welder and 6013 rod to lay a bead on both worn faces of the shifter tip. Followed this with a bit of quality time with a 4-1/2" grinder, alternately smoothing and test fitting until the tip slipped in easily and it shifted smoothly.
This was 6 or 7 years ago - the tractor still shifts great.
glennster
02-04-2008 07:41:05
i would use the mig welder. brass would wear out a lot quicker.
