A Farmall narrow/wide front
Tom Graham
02-05-2008 11:20:10
I looked at an A that had a narrow front, probably from a B, instead of the usual wide front. In order to return to original, does the lower casting have to also be changed?
gene bender
02-05-2008 15:41:17
 Re: A Farmall narrow/wide front in reply to Tom Graham, 02-05-2008 11:20:10
Like Hugh said over the years these little tractors have had many changes what you seen was probably a B with left side diff housing removed and using diff shaft from an A you can move the wheel in works good with a belley mower as the rear is narrower than 6ft thus the mower sticks out on both sides. They didnot leave the factory that way.
Tom Graham
02-05-2008 18:19:48
 Re: A Farmall narrow/wide front in reply to gene bender, 02-05-2008 15:41:17
Actually it's a 140, definitely not a narrowed up B, it has hydraulics. It was originally yellow.
Hugh MacKay
02-06-2008 04:47:34
 Re: A Farmall narrow/wide front in reply to Tom Graham, 02-05-2008 18:19:48
Tom: Then someone has installed a B front casting on a 140. From 39 to 79 there were only 3 basic castings and there will all bolt to the front of a C-113, C-123, C-135 and even the C-153 engines. There were probably more than 3 part numbers, however 3 basic designs, A, SA, etc.; B and C, SC, 200, etc. C type will take narrow front, however steering shaft is on the left.
Hugh MacKay
02-05-2008 13:38:50
Tom: The front casting on an A and B are different. What you may have is a B that someone installed a short housing from an A on the left side. There is one not far from me, very much like yours and it is a B with what looks like A rear housing. Get gene bender's ear, I seem to remember discussion on here, and the idea was floated that some B's were sold that way. I'm just not certain what came out of the discussion.
