86-88 series range trans removale tool
Joe L.
02-06-2008 17:01:51
can anyone explain the procedure for removing the range transmission cover on say a 1086 using the IH tool, so you don`t have to remove the side cover. I`ve done plenty by removing the side cover and know that routine. I bought the tool but am not sure where to have the shift cams or how ya use the the bent angle tool? The press part is staight forward enough but I know ya have to do something to get the Hi-Lo cam past the rev. arm. I`d appreciate any input Thanks
RR Mech
02-06-2008 20:36:04
 Re: 86-88 series range trans removale tool in reply to Joe L., 02-06-2008 17:01:51
The puller piece just lifts the top off while keeping the reverse shaft in the tractor. The angle iron piece is used to hold the detents and spring in place while lowering the cover back down. once you get it apart you can probably figure it out. It goes on the front left of the cover. the one notch inthe end goes against the detent arm and the other notch hooks on the dowel pin on the cover. Hope this helps.
Joe Schmitt
02-07-2008 05:58:02
 Re: 86-88 series range trans removale tool in reply to RR Mech, 02-06-2008 20:36:04
Thanks for the reply ,don`t ya have to have the shift cams in the right positions for the Hi-Lo cam to miss the rev arm as the cover comes up?It seems that the when the cover is up about 1/2" something is holding it from comming up any further.
RR Mech
02-07-2008 20:10:45
 Re: 86-88 series range trans removale tool in reply to Joe Schmitt, 02-07-2008 05:58:02
Yes it can catch and bend one of the detent arms. If you know right where to push with that tool you can help get it off. I usually just bend it and then put in a new one. If it catches really hard then the pin is working out of the park arm and can be a real fight to get it apart then. Good luck hope this helps a little!!!
Joe Schmitt
02-08-2008 06:42:57
 Re: 86-88 series range trans removale tool in reply to RR Mech, 02-07-2008 20:10:45
Thanks for the reply RR. I forced the cover up and and did bend the detent arm , but intended to replace it any way. I`ve had a couple where the park arm pivot pin has slid back.( Thats a real son of a B****. ) After I got the cover off I see how the tool fits on the dowel peg and then against the detent arm .( Thanks RR for that info). It doesn`t matter where the Hi-Lo cam is. Got it back together, works good. Saved about 2hr and the need for help. Thanks again maybe I can help somebody sometime. Joe
RR Mech
02-08-2008 19:55:26
 Re: 86-88 series range trans removale tool in reply to Joe Schmitt, 02-08-2008 06:42:57
Glad to have helped. Have had dozens of them apart. those tractors are real good tractors and will last forever. Good luck.
