serial # imformation
broderek57
02-07-2008 04:42:17
got an I.H. 434 and was wondering what the serial #"s mean, there B1169 on the body and BC144 11150 on the block,any help would be great, thanks.
neblinc
02-07-2008 12:42:59
 Re: serial # imformation in reply to broderek57, 02-07-2008 04:42:17
I can't be of to much help. just that the serial number on the plate most usually represents the number made, starting with 501 as the first number.
doing some searching on the web, the 434 was produced from 1966-1971, so I am guessing that yours would be a 1966 model if they made 500+ that year.
The number on the block most of the time should match the plate number. So I can't help you. the engine might have been replaced but I am no expert at all on this.
Just good at searching :)
Randy
neblinc
02-07-2008 06:46:44
Don't see 434 listed in the serial numbers section on the left side of this page. Serial Numbers
Are those numbers cast or stamped on?
Randy
broderek57
02-07-2008 12:20:26
 Re: serial # imformation in reply to neblinc, 02-07-2008 06:46:44
Hi randy the B1169 is stamped on a I.H plate and the b144 11150 is stamped on a embossed flat the way you"d generally find on a motor block.As far as I know these models were only sold here in Canada,Austrailia and Doncaster England where they were produced.
