Governor C
Kristof
02-15-2008 07:46:40
Hey Guys, I got my new bumperspring in my Governor. I tried running my engine (Farmall C) and the darn thing keeps hunting very badly!
Just can't keep a steady RPM, even tried screwing it all the way in.
I've been working at it all day now, and nothing seems to help...
Any ideas?
Thanks!
Bob
02-15-2008 12:38:29
 Re: Governor C in reply to Kristof, 02-15-2008 07:46:40
"Hunting" can occur when the carburetor can't make a smooth transition from it's "idle" to it's "load" circuit and vice-versa.
This can be caused by clogged passage(s), or a bad gasket not sealing the two halves of the carburetor together in the idle circuit or venturi area.
Andrew Z
02-15-2008 11:37:21
You need to adjust the linkage to the carb. I had that happen on my Super C, and i did eveything... and it was just a couple of turns of the ends one way or the other and that did the trick.
Andrew
Kristof
02-15-2008 11:43:19
 Re: Governor C in reply to Andrew Z, 02-15-2008 11:37:21
Andrew,
I checked the linkage according to my I&T manual, and it's in order... I've checked and did everything I could think of ...
Andrew Z
02-15-2008 11:57:14
 Re: Governor C in reply to Kristof, 02-15-2008 11:43:19
I know the way the I T tells you but it doesnt get them 100% of the time adjusting them like that it gets them close but not right on. I would give that end a turn on way or the other, just for haha's its really easy so i would give it a try if it were me, but that knowing my past experence with that surging.
Andrew
Kristof
02-15-2008 12:11:09
 Re: Governor C in reply to Andrew Z, 02-15-2008 11:57:14
I'll give it a shot in the morning my friend.
One of my friends told me it could also be that my ignition isn't timed right, although I don't think that's my problem. Just throwing it in, wondering what you think about it?
Andrew Z
02-15-2008 12:14:52
 Re: Governor C in reply to Kristof, 02-15-2008 12:11:09
It could be... but i wouldnt thing soo if its timing youll know it, itll miss, and skip, not runn steady at all. Not say it its it but thats not where i would look first.
Andrew
Kristof
02-15-2008 12:18:49
 Re: Governor C in reply to Andrew Z, 02-15-2008 12:14:52
It appears I'll have my work cut out tomorrow :).
Ow well, solving those kind of problems can only make us smarter right? Thanks Andrew
