Need H Water pump bearing spacer?
dep
02-15-2008 14:55:22
I just assembled the water pump on my H and discovered that it's hard to turn once the nut is tightened down. The book says the probable cause is that the bearing spacer is too short. I called around but that part is discontinued. Anyone else have this problem? What is the correct length of the spacer? Maybe I could make one up.
akb
02-15-2008 21:31:12
 Re: Need H Water pump bearing spacer? in reply to dep, 02-15-2008 14:55:22
With the new felt seal in there it will drag because of the newly compressed felt.
Kevin Meier
02-15-2008 16:35:14
If you used the old spacer over I doubt it"s the spacer causing you the problem. Was the pulley pressed down over the center tube or tightened down with the nut to draw it down. The nut stops at the correct height to keep the pulley from bottoming out to hard on the felt washer under the pulley. Or possibly the pulley was completley torn apart and the bottom pulley groove wasn"t pressed back on far enough. I have built a lot of those pumps and have never had to adjust a spacer.
dep
02-15-2008 18:31:05
 Re: Need H Water pump bearing spacer? in reply to Kevin Meier, 02-15-2008 16:35:14
The pulley pretty much slips right down over the center tube without much effort, so there was no need to press it on. I did not take the pulley apart. The only thing I have changed is the front/rear bearings. I did install a .030 shim in there between the bearing and the spacer and it was perfect when I preassembled it. Put it all back together with the seals and felt some drag when the nut was tightened down. Pulled out the felt seal and tried again and no more dragging... so thats what was causing the drag.
Nebraska Kirk
02-15-2008 16:12:35
Or you could try adding some shims untill it turns freely without any forward and back play.
