1466 Shifting Problems
skyharborcowboy
02-17-2008 00:17:29
I am trying to help someone out and explain to them that "I believe" that there is an internal transmission problem and not simply a simple shifter bushing problem as they believe it is. I think it is worn shift forks or possibly worse.
Here is the scenario: The tractor is harder then heck to get into any gear and will seemingly find its way into two gears at the same time because when you let the clutch out the engine just wants to bog down and stall. Sometimes there is some grinding of the gears while tring to engage a gear but the clutch does its job very well.
How much does it cost to go through a transmission on one of these tractors replacing all of the normal wear items and what are some of the common items to go wrong with these transmissions in these tractors? One of my neighbors said that this type of failure is very common in this model of IH tractor. He confirmed my diagnosis but I wanted further confirmation from you guys to help this friendly couple that I met the other day to help them out.
Thanks,
Joe
skyharborcowboy
02-17-2008 12:36:35
 Re: 1466 Shifting Problems in reply to skyharborcowboy, 02-17-2008 00:17:29
Ben,
On the www.caseih.com website parts website, could you point out the part that was broken on your particular tractor that was in your shop? There are a couple of sections that it could be under for clarification 7-11, 7-51, 7-52, 7-54 or 7-55. Since I am sure we have the same problem it would be a great help to know.
Thanks a ton,
Joe
skyharborcowboy
02-17-2008 12:28:11
Ben,
Was it the fix an external fix or did you have to get into the transmission itself? How much were the part and the labor? Were specialized tools involved? How many man hours were involved? This tractor also does not have a cab installed. I believe that what you are saying about one of the forks being broken off sounds about right because it feels like the speed fork just flops around and you just have to hunt and peck and hope you can find the one sweet spot to get it into any one gear.
Thanks,
ben brown
02-17-2008 04:06:06
joe had a 966 come into my shop other day was acting like you describe. they had broke one of the shifter forks in the speed transmission. the shift lever on the out side control them. you can get to them and replace them by removing the steering colume. not to bad a job. not all that easy eather this one didn't have a cab eather. also make sure before that it hasent shered the pin where the shift shaft go into the top if the transmissin.
