New F-20 frame rails
scott rukke
02-18-2008 11:54:07
third party image
Brand new frame rails on my 38. Put the old drill press to a test. About 4 hours worth. Everything has lined up perfect so far. Laid the old rails on the new ones and sprayed paint through the holes. This gave a perfect template to drill on. Lots of heavy work though moving these things around. They are heavy.
louis j waite
02-19-2008 18:28:01
 Re: New F-20 frame rails in reply to scott rukke, 02-18-2008 11:54:07
wondering if any body new where I can find a pressure plate for a F20
Scott Rukke
02-19-2008 18:40:42
 Re: New F-20 frame rails in reply to louis j waite, 02-19-2008 18:28:01
You can try Howard at: howster@nebnet.net
or Dale at: oldiron@wildblue.net I got mine by posting in the wanted ads on the left of this page. Howard has one on ebay right now, Item number: 320075398304
Armand Tatro
02-18-2008 17:45:47
I believe the F seris had the ID numbers welded on the outside rear of the frame rails. Did you weld these numbers back on the rails? Armand
Scott Rukke
02-18-2008 19:26:29
 Re: New F-20 frame rails in reply to Armand Tatro, 02-18-2008 17:45:47
They're stamped on the top of the left rail right behind the clutch. I have them stamped there and they look good.
Armand Tatro
02-23-2008 05:17:40
 Re: New F-20 frame rails in reply to Scott Rukke, 02-18-2008 19:26:29
I have 3 F 30s that the frames have been altered and the S. N. have disappeared. I was hoping you saved them. Armand
oldiron29
02-18-2008 13:31:33
Scott, Looks like a good start to a nice tractor.
I have measured my F-20 NT round spoke 11.2 x 36 tire Rim hubs in 73" rim hubs out 82"
If you have steel what type? Is it wheatland spokes or off set row crop. On my regular NT I have off set steel with overlay band It is wider from lug nut to nut 71" than the wheel edge On stanard tread should be 12" wider. oldiron29
Scott Rukke
02-18-2008 14:27:56
 Re: New F-20 frame rails in reply to oldiron29, 02-18-2008 13:31:33
third party image
Here are the steel wheels for it.
oldiron29
02-18-2008 14:59:55
 Re: New F-20 frame rails in reply to Scott Rukke, 02-18-2008 14:27:56
Scott, I think those rear look like wheatland
Are the hubs centered in rim or out to one side?
If they sit to one side there should be the same measurement I gave you. these rims are rolled steel with a lip on edge. My off sets are 5/8" thick steel band with no edge lip and every other spoke is doubled up. If I had a picture I would send it. oldiron29
Greg NE
02-18-2008 12:40:59
Just wondering, but what was wrong with the old ones. I'm in the process of restoring a 37 and mine don't look too bad just alot of old paint. Greg NE
scott rukke
02-18-2008 13:10:37
 Re: New F-20 frame rails in reply to Greg NE, 02-18-2008 12:40:59
They were extremely corroded both inside and outside on the ends where the cultivator brackets attach. Good thing I took them off because several of the bolts had only about an 1/8" of material remaining in the centers and they all snapped in half.
russ hamm
02-18-2008 12:11:54
Nice work. A narrow tread, too. I really like the narrows as i can haul them on my trailer.
scott rukke
02-18-2008 12:40:14
 Re: New F-20 frame rails in reply to russ hamm, 02-18-2008 12:11:54
How wide is your trailer? I am a bit worried about this one fitting on mine.
