Order Farmall Cub Parts Online
53'cub right rear final drive
tooltime
02-18-2008 18:16:00
third party image
took off right side final drive, i need to replace brake band, i found that axel was welded and brake drum was loose. i tightened up set scre on drum and it seems to hold to axel . think i should try find a axel or go aheah with brake band replacement the way it is... any thoughts, thanks, jim Ill send a pic , i think you will see the weld going around shaft .
mkirsch
02-19-2008 05:06:36
 Re: 53'cub right rear final drive in reply to dave guest, 02-18-2008 18:16:00
The brake drums are notorious for coming loose on Cubs. A previous owner probably had that drum come loose on multiple occasions, and finally got fed up with having to tear the tractor down to fix it. He tried to weld the drum to the shaft, but it obviously didn't work.
Sometimes welding is necessary, as "fixing it right" simply doesn't work, or isn't an option due to cost. Case in point, the steering arms on the 756 worked loose. No amount of tightening, new keys, shimming, etc. was a permanent fix. They'd always work loose again in a short amount of time. To "fix it right" would've meant new spindles and steering arms, well over $1000 in parts to fix a slight amount of wear in one spot. Dad hated to do it, and tried every alternative short of new parts or welding before finally giving in and running a bead around the top of each steering arm. It's been like that for 15-20 years now.
Roger46
02-18-2008 18:53:33
 Re: 53'cub right rear final drive in reply to tooltime, 02-18-2008 18:16:00
I am amazed at what people weld on old tractors. My cub had the front steering arms welded and some other parts welded. Many times rather than fixing something right, they just get out the welder and stick it together. Who knows how well your drive shaft is welded. I would be concerned about how straight the shaft is after welding. I would replace it if I were you. You can get parts from the cub web site (TM Tractor Parts). Roger
tooltime
02-18-2008 19:11:48
 Re: 53'cub right rear final drive in reply to Roger46, 02-18-2008 18:53:33
thanks roger. i will look for one. fix the right way is best
tooltime
02-18-2008 18:19:42
the weld is all the way around axel in front of brake drum. why would anyone do this, i dont understand the logic here, thanks for looking
