missing 766
Troy Schwartz
02-24-2008 20:19:48
Hi I have a 766 gas tractor and when I pull the plug wire on the #2 cylinder the sound of engine does not change like the rest of them (dead cylinder) can anyone help? also does anybody know if my fasthitch has down pressure?
andy rowe
02-25-2008 12:23:51
 Re: missing 766 in reply to Troy Schwartz, 02-24-2008 20:19:48
I had a burnt valve on my 706 gas. You can check for compression with your finger over the spark plug hole if it is as bad as a burnt valve. I believe these engines tend to carbon up which is one cause of valve margins burning. This is the reason for the "low ash" oil recommendation. Just a possibility.
mkirsch
02-25-2008 06:21:19
 Re: missing 766 in reply to old, 02-24-2008 20:19:48
If you've got a situation like Allan's picture, then it'll be missing on TWO cylinders...
Since you're only missing on one, I'd suspect a bad plug or bad plug wire first. Swap the #2 and #3 wires (on BOTH ends!!!!) first, and see if the miss follows the wire. If it does, get a new set of wires. If not, try swapping the plug. If the miss follows the plug, get new spark plugs.
If new plugs and new wires don't help, do a compression check. You may have burned/stuck valves on #2, or you may have hammered a hole right through the piston by not running enough octane... :(
Allan In NE
02-25-2008 04:03:04
If it's missing on # 2, I'd be for putting a compression guage on that thing.
Allan
third party image
Larry NCKS
02-25-2008 01:19:09
 Re: missing 766 in reply to El Toro, 02-24-2008 20:19:48
no down pressure to 2 pt. You have a bad plug, plug wire, distributor cap, valve, or vacuum leak on # 2. Check firing first. If that isn't the culprit, run a compression test.
