Wide front end 560
BEDROCK1234
02-27-2008 05:09:33
Does anyone know if the wide front end off an 806 or 706 will work on a 560 Farmall?
kippster
02-27-2008 09:15:47
 Re: Wide front end 560 in reply to BEDROCK1234, 02-27-2008 05:09:33
We took the wide front off of my friend's 560 and put it under his 706. It was a little light duty, but it worked fine for the light work we did with it, like raking and baling with the square baler.
Hugh MacKay
02-27-2008 17:13:51
 Re: Wide front end 560 in reply to kippster, 02-27-2008 09:15:47
kippster: Pray tell how did you discover that. The factory wide front of 560 and 706 are exactly the same, with the possible exception of the wishbone. I've seen them parked side by side many times.
Allan In NE
02-27-2008 07:34:30
Biggest share of it will.
Measure the width of the two tractors. :>)
Allan
IaGary
02-27-2008 05:38:59
Yes
