Super-A touch control, Pa. style
P and R Pete
03-01-2008 13:13:32
Finally got my feet wet.
AND my pants. Again.
I was pulling parts out the back, and pushed a rockarm forward, and I got baptized all over again. I'm going to be the Holiest Farmall owner east of the Missip! Fair warning to anyone yet to 'jump'.. there's plenty of hytran still lurking in those bores.
On the other hand, everything came out easy without needing any special tools, so I can't complain.
third party image
third party image
Sam or Greg, this leads to some questions...
You guys take those big nuts off the rear of those pistons while they're still in their bores? I don't want to damage the bores, (those suckers are on TIGHT), but it seems like it would be easiest while everything is still held still.
After that, does it matter if the pistons come out the front or back? I know the control valves have to come out the front.
The boots held on by anything, like do they fit over a lip, or spring-held, or such?
Last, I suppose I'd figure it out if I had to, but my front end is a crudded mess, and despite the IT Manual, it isn't real "self-evident" to me how it comes apart. Either of you pros willing to give me a good word?
On the downside, my oil strainer mesh has a 2-inch circumferential tear.
I wonder if there's any new strainer, or boots, to be had anywhere.
In the meantime, I'm hitting the road to go find me something to get that Pressure Regulator Valve Seat out, and some pads for my grinder to get that gasket-from-HELL off.
Jim Bynum
03-03-2008 10:19:18
 Re: Super-A touch control, Pa. style in reply to P and R Pete, 03-01-2008 13:13:32
Hello,
I just rebuilt my 1952 Super A hydraulic cylinder block last weekend. I installed a new kit of o-rings and gaskets from the CaseIH dealer. I noticed a couple days later my control valve o-rings were leaking. So I got new o-rings separate from the kit and installed these last Friday night. It appeared these o-rings had a slight thicker wall. I thought this was going to work but it started leaking later Friday night and is still leaking. Anyone have any ideas what I can do next? I have looked all over for thicker o-rings with the 1/2 inch I.D. to match close to what the control valve requires. Everybody I talk to says they had no leaks after installing the o-rings even the CaseIH dealer mechanic. Someone recommended teflon orings but I can't see how I would stretch a teflon o-ring over the shaft.
thanks,
Jim
Greg-N-CA
03-01-2008 19:54:46
I really appreciate all the interest from the previous post(s), this SA restoration project has been both frustrating and enjoyable. During the week I can’t wait to get home to work on it and on the weekends there are chores to do. What’s a rust and grease freak to do?
Pete, congratulations, you took the leap! Not so bad was it? The piston and connecting rods come out as a unit. The pistons are removed through the back (head end). Remove the nuts after they are out, clamp the connecting rod in a vice (with brass jaws) and loosen the nut. The bolt has a tapered shaft and will require the encouragement of a brass hammer to separate. IHC Dealers will have the boots and strainer.
“My front end is a cruddy mess,” are you talking about the front axle and steering box? I took mine apart (thanks to Hugh’s advice) and it not so bad. The only bugger I ran into was pulling the steering arm off to be able to separate the box. If you have issues when you get there, email me and I’ll be happy to share my experiences.
Hugh, it sounds like you’re considering going into your touch control. After what I’ve found I would recommend doing it. My pistons are pitted and are not serviceable. I’ll have to find a source for these, I’m sure they will not be inexpensive! You will find flat o-rings that are at the end of their service life (if not beyond). Anyway, it’s really not a difficult project.
Here is our web page of progress on the restoration:>Link
Regards,>Link Greg
P and R Pete
03-01-2008 20:17:54
 Re: Super-A touch control, Pa. style in reply to Greg-N-CA, 03-01-2008 19:54:46
Ah. The boot then gets fed through the casting? Doesn't seem like it would fit over the bushing end of the connecting rod.
And the pin that goes through the connecting rod bushing- it comes out after separating the pieces of the bracket that constrains it?
P and R Pete
03-01-2008 20:20:53
 Re: Super-A touch control, Pa. style in reply to P and R Pete, 03-01-2008 20:17:54
And no, sorry, I meant the front end of the touch control casting was filled with crud. Oil and dirt and chaff and mud wasp nests. Made it heard to see what came apart. I want to get those rockshafts and pillowblocks out of the way.
Did you get out your safety valve piston? Find the source of the rattle?
Greg-N-CA
03-02-2008 06:03:13
 Re: Super-A touch control, Pa. style in reply to P and R Pete, 03-01-2008 20:20:53
third party image
Pete,
Remove the pins from the connecting rods and the rockshaft, setting it aside. Remove/cut the leather boots off; then drive the pistons and connecting rods out of the block through the back (head end). I had to persuade mine with a friendly tap on the end of the connecting rod to get them moving. You’ll see the stops that need removing to get the control valves out once you have the rockshaft out of the way. I hope this helps, Greg
Greg-N-CA
03-02-2008 06:28:41
 Re: Super-A touch control, Pa. style in reply to Greg-N-CA, 03-02-2008 06:03:13
I haven't been back in to get the safety valve piston out or find the rattle. I take it you don't have any noise when turning your block over. I plan on pulling all the plugs and cleaning the passageways thoroughly today. Hopefully the "rattle" will show itself during this phase.
Have you tried removing the pressure regulator valve seat yet? I'll probably need to make a tool to remove it. My largest screwdriver doesn’t budge it.
glennster
03-01-2008 18:09:46
pick up an aerosol can of spray gasket remover. spray it on , let it soak 10 min or so, scrape it off, repeat as necessary. works really well for getting them old baked on gaskets off.
tractorsam
03-01-2008 14:13:57
I haven't yet tackled the pistons, maybe tomorrow so I can't help you there. The boots on mine were held on with wire and the ends were twisted together. My boots are in very good shape, you'd never know they were 50 years old. Where the wire is tied on the fit into a lip but with some wiggling they pulled free (after removing the wire).
I think strainers are still available but you might want to try soldering it first. I know someone (we'll not mention any names here but I know him really well :) who stuck a screwdriver through one and managed to solder it together again.
On that gasket, I find it comes off fairly easily with a decent razor blade scraper. Not much more trouble than any other gasket.
tractorsam
Hugh MacKay
03-01-2008 13:48:15
Pete: Great progress, I'm watching and learning from all you, Greg and Sam are doing. I'll have all the do's and don'ts by the time I get to mine in two weeks. I've had 6 of these tractors since 1958, always managed to avoid a hydrulic kit. I'm certain Randy thinks I'm overdue. Sam probably does too, he was here just after Christmas, he knows where my oil stains are.
NDS
03-01-2008 14:49:43
 Re: Super-A touch control, Pa. style in reply to Hugh MacKay, 03-01-2008 13:48:15
I have been in denial about lift all leak in my M. Went by convenience story few days ago and they had closeout on 30W non detergent oil for 59 cents, bought 24 quarts and have leak covered for few years.
NDS
03-01-2008 14:49:14
P and R Pete
03-01-2008 14:20:18
Uh-oh, Hugh, sounds like your 'head-scratching' has led you to a decision!
Me, straggling along behind, I'm just "standing on the shoulders of giants"! (Sam and Greg) (LOL)
tractorsam
03-01-2008 14:16:24
The one on my Super A is probably long overdue as well. It doesn't leak (too much) but it certainly doesn't work as well as the one on your 130 does. I was pretty hesitant about getting into this but now that I'm well into it it's not as bad as I anticipated. tractorsam
Hugh MacKay
03-01-2008 15:01:35
 Re: Super-A touch control, Pa. style in reply to tractorsam, 03-01-2008 14:16:24
Sam: There is an interesting side note with all of these touch control units. They always leak if lifting heavy loads as the rockahafts go towards the rear, or cylinders retracting. If you never put that type of load on them, I don't think they would ever leak.
My blade lifts that way, as does the factory blade. When I first had my blade, I had it on the Super A first winter. It caused the hydraulics to leak around the rams. That was 1990 and the Super A torque tube dried off 6 months after I last had the blade on it. Since that time the blade has been on my 130, same thing, all winter the torque tube is wet with oil. By the end of june it's dried up.
I think if folks would refrain from using touch control on retraction lifts, leaks would be less previlant. I would advise anyone looking at using a blade, go to an implement cylinder and remote valve.
You drove my 130, that tractor has been through the mill 10 times over, on is 3rd set of pistons and sleeves, yet hydraulics have never been apart. On that big disk I have using my 3 point hitch kit, the 130 lifts that disk to full height easier than my 140, and I doubt if the 140 has seen 500 hours of work lifetime. But then you get right back to what I said on Greg's thread this morning about tractors parked for long periods. The lubricants drip down from the upper extermities of every component as in engine, hydraulics, transmission and rear end plain any simple, over time oil is replaced by rust, and rust causes far more damage than use. When farming I saw this with big tractors, when hours went on fast and furious the repair cost per hour is far less than the tractor doing couple hundred hours per year.
Of course one of the big live hydraulic problems with IH tractors out of the 40s and 50s, the reservoirs were too small, many of them got low in oil and had more than one hot session. It required close scrutiny of hydraulic oil levels. Then you had the operator that decided since he wasn't using hydraulics, no need to check the oil level. I always tell those folks, that hydraulic pump will last as long without oil as your heart will without blood. Usually jolts them a bit.
tractorsam
03-02-2008 08:33:35
 Re: Super-A touch control, Pa. style in reply to Hugh MacKay, 03-01-2008 15:01:35
I know what you mean about using the tractors. 90% of my problems come from having things sitting around. If I used them weekly even I wouldn't have half the trouble that I do.
When I first got the Super C the hydraulics worked fine and then after using it a while they started to leak down if you left a load on them (or more annoying the fast hitch drawbar would drop). Then after I discovered the state that the timing gears were in I decided it was time and the touch control would have to come apart. The o-rings are all pretty well perished and on the check valves there are small springs at each end. One of these was broken, jamming up the check valve. Also with no filter on the system it can't do any harm to clean it out occasionally. tractorsam
