Order Farmall Cub Parts Online
Cub/A Belly Disk Plow
Greg Lasher
03-02-2008 12:32:13
Does anyone have any expereince using the disk plow that mounts under the belly of a Cub or an A? Is it supposed to work like the rear disk plows? I was told the rear ones are great for rough plowing where there are stumps and brush - is that true for the belly plow? How good do they work?
Thanks
Greg
john *.?-!.* cub owner
03-02-2008 19:33:43
 Re: Cub/A Belly Disk Plow in reply to Greg Lasher, 03-02-2008 12:32:13
The belly mount is great for gardens, etc. but in hard ground, roots, etc. it tends to shove you sideways.
banjo
03-03-2008 06:24:20
I've got one on a cub and it does pretty good in my clay ground. I have 1 set of weights on the rear.
if you have stumps or large rocks it will stop you in your tracks.
gene bender
03-02-2008 13:27:02
I have never used one but the fellows from TEXAS who used them told me you need light soils for them to work well.Just remember you dont have a lot of HP or wt of the tractor so that tells me something.
gene bender
03-02-2008 12:44:09
Those work well in loose soils and dont need any brush or other stuff unless you want a wreck and tear stuff up/
