How draft control works
Jack a
03-05-2008 13:25:42
In order to beat a dead horse..... draft control "Traction Booster" when plowing uses the weight of the plow, soil and front end to add traction to the rear wheels when the going gets tough through linkage from the hitch to a valve. As the load grows the valve is activated and puts upward pressure on the hitch and causes the weight transfer to occur. Almost all of the weight of the plow along with the soil and a portion of the front end weight can be transfered without raising the plow at all. Suction created by the plow should keep the plow in the ground. If the mounted plow won't stay in then neither will a pull-type or any other (unless your points are dull or the plow isn't winger properly).
If the plow is actually raising then the draft control is incorrect. You should set the plow according to the toughest portion of the field and if your ground requires your tractor to be heavier then the farmer puts wheels weights on accordingly. I saw a tape done by Allis where they took a tractor and locked out the traction booster and gave the tractor a measured quart of gasoline and was able to plow 1,200 ft then with the same tractor and 1 quart of fuel and this time using traction booster They were able to plow 1,500 ft. Both times they started with an empty carb. That's quite a fuel savings.
Evidence for me is plowing with my little D17 and easily outperforming a tractor with 10 more hp that is pulling 1 bottom less in very hard ground.
Allan In NE
03-05-2008 17:05:13
 Re: How draft control works in reply to Jack a, 03-05-2008 13:25:42
Are you talking about pull-type plows? Semi-mount or what? Are you talking IH tractors?
However, on a mounted plow, the draft is actuated by torque load, it controls the suck/depth of that plow and the tractor is already carrying the weight of the plow to a large degree.
Suck is pulling "down" like you wouldn't believe. Tractor and draft are constantly trying to pull it back up out of the ground to maintain the correct level as set by the draft lever.
It's a continual give and take action and you can watch it work by watching the lift arms.
If you don't believe it, pull the position lever back up out of the "run" position. You'll feel it cylcle just about every two to three seconds as the suck of the plow pulls itself back down deeper and the hydraulics will then correct again by raising the plow.
Plow weighs the same to the tractor wheather it is in the ground a foot or out of the ground the same amount (not counting the balancing act on the guage wheel).
Stop the forward motion and the plow "weighs" less as far as the tractor is concerned because there is no suck.
Don't know how Allis tractors work; never owned one.
Allan
third party image
Hugh MacKay
03-05-2008 16:46:09
Jack: You've got it right on, however witness the other thread, 85% of folks don't know how to set their draft control.
Allan In NE
03-05-2008 17:14:30
 Re: How draft control works in reply to Hugh MacKay, 03-05-2008 16:46:09
And the other 15% don't know how to put a plow in the ground.
Allan
Hugh MacKay
03-05-2008 17:53:33
 Re: How draft control works in reply to Allan In NE, 03-05-2008 17:14:30
Allan: No more plow discussions for me. I plan to take part in antique plowing competition this summer, don't want to give my secrets away. Looking at this group, not sure whether the plows or the operator's are the antiques. Either way, I'll change it very little.
