140 Drawbar question
big red 1
03-07-2008 08:05:14
Will a drawbar from a Farmall B fit a 140 if so will the swinging attachment work as well?
Thanks in advance
Randy In Iowa
Hugh MacKay
03-07-2008 14:22:21
 Re: 140 Drawbar question in reply to big red 1, 03-07-2008 08:05:14
Randy: No the drawbar wont fit, B is about 18" wider. The swinging bar may fit. If your good enough with tourches and a welder you can make them both fit, but then you'll need SA-140 type final drive plates for attaching drawbar. In short, you'll find the proper drawbar for less money.
tn terry t
03-07-2008 12:59:09
 Re: 140 Drawbar question in reply to Re: 460 is a knocking..., 03-07-2008 08:05:14
big red 1 said: (quoted from post at 05:05:14 03/08/08) Will a drawbar from a Farmall B fit a 140 if so will the swinging attachment work as well?
Thanks in advance
Randy In Iowa
Randy the B is a lot wider in the rump than the 140
