volt meter
Don from Indian
03-08-2008 12:33:20
On a SMTA 12 volt conversion, how is a volt meter wired compared to how the amp meter is wired in Bob M's diagrams?
Sam#3
03-09-2008 07:32:46
 Re: volt meter in reply to Don from Indiana, 03-08-2008 12:33:20
Be sure you wire it so it's 'swichable.' A voltmeter draws current and if connected to a battery lead it will deplete the battery over time.
Bigdog
03-08-2008 13:46:01
A voltmeter is wired across the circuit (hot side to ground). An ammeter is wired in series with the hot line. Wire the voltmeter from the alternator output terminal to ground.
